Try a factory reset if possible else you may have to take it to the dealer. Although if I am not mistaken the warranty may not cover software updation issues. The Marantz dealer had cautioned me to regarding updation over the net since in India the connections are not so great & to get a pen drive to the dealer for the firmware.
Here are some reset steps - presume you have tried them
UPDATE / UPGRADE VIA NETWORK ABORTED OR INCOMPLETE
marantz-uk.custhelp.com
A very long time ago, I had helped a friend recover a similarly bricked Denon AVR using an appropriate FW file downloaded from the Denon site..
Wasn't easy to locate IIRC
Denon and Marantz use a very similar architecture so something similar may work
My dealer had cautioned me too.This was done mistakenly.
Never mind what's happened has happened. Pls try a reset or request the dealer to help you out or worst case scenario pls email marantz.
The Indian dealer is MZ Audio in Mumbai, Bandra(W).
Musical Instruments – Musical Instrument Maker Website
mzaudiodistribution.co.in
Nos 022 26401411/12
Akbarbhai mob 9870287687
Akbarbhai is in charge of repairs but in the current Covid 19 situation they will be shut. But pls ask him for a solution on the mobile if possible.
Thanks for this.
I have bought my AVR from MZ Audio only.So, when you mentioned about the dealer mentioning that don't do an update, I thought we are talking about the same person.
Great!Hi Mate, Thanks for this tip. AVR is now functional![]()
Good to know. Did you factory reset your AVR?Hi Mate, Thanks for this tip. AVR is now functional![]()
Yes. I did. In that shared link by Supercarz. It has the process to Factory Reset based on your model number.Good to know. Did you factory reset your AVR?
What did you do to factory reset that?Yes. I did. In that shared link by Supercarz. It has the process to Factory Reset based on your model number.![]()
The option related to the respective Model number I tried. It worked for me.What did you do to factory reset that?
I found the page using webarchive and tried resetting using zone2source+internetradio buttons as suggested by the page. The display blink like it was said on the page then show various input then the update retry sign was gone.
But now i still can't do anything with it. The GUI won't show up on HDMI. Buttons on the remote that needs GUI like SETUP or OPTION also didn't respond. And there's no sound coming out from my receiver. Bluetooth and USB was detected but still no sound
Hi Balzac, How did you made id? Did you find usb firmware for 1606 maybe?Hi Mate, Thanks for this tip. AVR is now functional![]()
