A basic question - is there any difference if u take digital output coaxial from these players and feed to a Dac - meaning digital output will be of same quality?
Taking the coax digital out from Samsung DVD player compared to a say Marantz one or Cambridge audio - would that make any difference in the signal quality ?
I think there are two separate questions being confused here. One is the source and the other is the transport mechanism.
1. Is there a difference between a mass market DVD player and a dedicated CD Player? Yes and no. Let me explain. If you take a Samsung DVD player and compare it to a Marantz CD player, the Marantz will beat the pants off the Samsung keeping everything else the same. In most cases, a dedicated CD player from Cambridge Audio will also beat the pants off the Samsung.
At the same time, if you take a Universal Player from Oppo and compare it to a Marantz or a Cambridge Audio, you will be hard pressed to tell the difference. Both players have dedicated circuits for audio. Of course Marantz has been a master in superb CD players for a very long time.
Will any dedicated CD player beat any mass market DVD player? - Nope. One can never give an answer to this question unless your specify the models. Marantz, CA and a lot of other companies make DVD/BD players that output very good audio also.
Now, when you take the digital out from a mass market DVD player and a dedicated CD player and feed it to a DAC, there will be differences. The difference is not because of the 'digital out' which is common in both cases. It is because the way the source picks up the information from the CD and sends it to you.
Now one can say, digital is digital. So why should there be a difference? Essentially because of two main points. The DVD player is designed to read denser information on a media of the same size. Now before people jump on me, please search and read a technical document I have written somewhere on HifiVision on this. This is, to sum it up, the same difference between data transmission and transmission of audio and video between any two digital points. In data transmission, the receiving end does a checksum error and requests for re-transmission. In audio or video there is no checksum error. So if the pickup head picks up an error, that is transmitted as is.
Secondly, in a DVD player, the internal circuit board is designed more for video than for audio. It does not care too much for the audio part.
A dedicated CD player is focused on just audio. It makes less errors when reading the disks, the processing of the audio is better, and so the resultant output will be 'better'.
What the 'digital out, S/PDIF or any other transport mechanism does is irrelevant here. What the DAC does downstream is also irrelevant for this discussion.
To answer a question raised by the OP further down - is Toslink better than co-axial - the answer is subjective. Technically, a digital co-axial and Toslink should deliver the same identical quality. The argument that Toslink is faster does not hold ground as the bandwidth of digital coaxial is more than enough for audio transmission. You really have to read the manufacturers recommendation and use the connection he prescribes. Remember, in most cases, processing digital coaxial output is easier. Processing Toslink is a bit more expensive and complicated - at both ends.
