Matching SR7015 preout with PM8006
Kairos
Pune
Hello All , soon I'll be getting the Marantz SR7015 and plans are to use the front pre outs into PM8006 (power amp direct in mode). According to the ASR's review ,the preout voltage of 7015 is less than 2volts which could be a problem driving a power amp to its max. Not sure what this statement exactly means nor do I understand that in the context of my use case. I'm concerned about volume level matching with other speakers so please help me to clarify if it's a good idea to use the pre outs of 7015 into the PM8006 for driving the front speakers. Thanks in advance.
Since you are planning to use just poweramp section of 8006, then there won't be an issue. Marantz avr output 1.2v and can be enough for poweramp to drive.
