Mini system to use with Wharfedale Diamon 10.1
udhay54321
Hello folks.
I was looking at the Wharfedale Diamond 10.1 group buy that still seems to be active (can someone confirm?) and was wondering what would be the best mini system to pair them with.
Requirements:
* Digital ipod input (i.e the ipod's DAC is not used)
* CD player
* Something around the INR 15k mark would be ideal.
I was thinking the Denon DM38DAB fulfills all these requirements, but am not sure where to find it in Bangalore. Any thoughts on this or other mini systems?
Thanks!
Not sure the GB is active (but admin will answer better).
For amp if you are on a budget then Norge 1000 should be a good match.
Not sure about a "budget" DAC but if you have a PC then an Asus Xonar soundcard will make for a great source.
Not sure about the Denon but going for separates will serve you better in the long run when compared to a mini system.
Otherwise if you have an old hifi at home (like Philips PowerHouse) then a CDP or even a DVDP that supports USB should also be good to start with.
