Mission M35i + Yamaha RX-V467 - Please Advice
tridentsenthil
Salem
I am planning to buy Mission M35i Floor standers + Mission MS-10 Sub + Mission MHT (center/Surround) + Yamaha RX-V467 as a package. Please guide me about the match. For example Yamaha RX-V467 India has 6 ohms output but the Mission speakers have 8 ohms. Will it match? Please help me out.
Impedance matching is no problem,in advanced setup menu you can select it as 8ohm.
regarding spk choices i will suggest you to audition different brands after searching various threads on this forum. pls search!!!, you will find plenty of options
cheers
Trident, There will be no issues. Thats a fine combo, and if you are happy after listening, go for it. But as mentioned above, try to audition as many other brands as possible before forming a decision.
thumbs up for the above setup...i auditioned them at alliance 4 in mumbai...how much were u quoted btw for the mission???
i was quoted 38k for the pair and 63k for the 5.1...
Thanks all for your great guidance and this is also my first post. I have auditioned with Mission M34i speakers not on Mission M35i as they were not available. but on M34i it was great.
Yamaha RX-V467 + Mission M35i FS + MHT (Center+Surround) + MS-10 Sub = 70K.
Once again thanks to all.
