MJ acoustic Reference 400 mk1
maniac_2004
mumbai
Hi All,
wanted your opinions on this subwoofer . Specs as follows -
250watt MOSFET Amplifier
Speaker and Line Level inputs with Gain Control Range 99dB
Neutrik Speakon connector (High level 100k ohm)
Unbalanced RCA (phono) connectors (Gold Plated) (Low level 10k ohm)
Twin Sophisticated crossover circuits - variable increments between 20Hz and 120Hz
LFE Bypass setting (effective roll off set at 200hz)
12 volt trigger
Remote Control with out-of-sight RM Eye and 4 user-presets
Phase Control infinitely adjustable between 0 and 180 * Frequency response 13hz to 200hz
D.I.P. (Dynamic Intelligent Protection)
D.A.M.P. (Digitally Accurate MicroProcessor 2nd generation)
Specially designed cabinet structure, volume, and configuration made from inert 18 & 25mm MDF
Digital Display with power output meter and frequency setting
Switched fused IEC mains input socket
300mm (12) Ultra Long-throw Driver with Heavy Duty Chassis & Double Magnets
UK 3 year manufacturers return to base warranty
Dimensions (WxHxD ) 345mm x 385mm x 345mm * Weight 16.23kg (35.2 lbs)
finishes available, Black Ash, Cherry, Oak & Walnut. All Real Wood Veneers.
Intrested as this is available in India .
You will find such specs for most well known and reputable subs. Unless one has some market knowledge of the product or has done a personal audition of the product, it is very difficult to say anything about it.
