Monitor audio vs Dali
I wont say Dali concept is very Bright , right now I'm using it with my Yamaha 667 receiver it has some brightness but not much compared to monitor audio which i used Earlier..I have heard it with Marantz7001 and the combo was so musical and 3 dimensional, Concept is a very good Floor standers that can sound tight like a bookshelf if paired with an amp in the range of 70 to 100 watts.,I have heard it side by side with Monitor audio BR series and this sounds very very musical.
Saran I have too acquired Dali Concept 6 speakers last month. Right now using them with DNM 8080 amp and my laptop with an external DAC from Asus as teh source.
Which amp do you use with your speakers? I am told 'warmer' amps like Sansui are better suited for bright speakers like Dali. What's your advice?
thanks
Nitin
