Mr.Tab
kaushik
wanted to welcome a Mr.tab
after selling my samsung P1000[no usb,takes hell lott time to charge , no tv out...arrrgh!]
i needed a tabbie in max 6k but dont see a suitable candidate.
The Need :in 6000Rs INR
*need it as Download machine 12 Hrs daily over wifi , should support 4GB+ files
as laptop powers off as power cuts happen,downloads less this way
*HDmi 1080p is must , Battery 4400mAH [many people never see this , this is needed as it will give min 6hrs video and full day net usage], capacitive
* android market , flash support .processor 1GHz will be better ,expandible mem till 16gigs
i believe :
*even if i get 15k moto xoom it get will not replace laptop ,so I will not expand budget
*usb port, fast charging is desired
*10/8 inch does not matter , 3g not needed ,china slates with user review can be accepted but i will not take any stuff with "push screeen!"
some ebay india tab with 1080 play is there ,but resistive screen
out of budget
mercury mtab :9k
nook used : 10k
Help me make good use of 6K;)
6k.. there is no tab that will infact have capacitive screen which is a must if you want good browsing....
HDMI can be there is few of them but they being capable of playing 1080p is a doubt..
hp touchpad at 14k is capacitive.. battery stays over 10 hours with video and wifi but even a dual core 1.2 over clocked at 1.5 the max it was able to play was 720p of 2-3GB... and thats bout it..
though people can input if any options available... coz i am not completely sure bout all the tabs..
Got our guy "NOVO7 advanced"----------just awesome 100USD ,just need to grab via Airmail freeship
Free Shipping Super Pad 7.0 inch Ainol NOVO7 Advanced Tablet PC with Android 2.3 Wifi/Dual Camera+2160P Functions 1.5GHz 8GB
Reference Ainol Novo7 Advanced
Operating System Android 2.3 OS
CPU A10
CPU Frequency 1.5Ghz
GPU Mali 400
RAM 512 MB
RAM Type DDR3
Internal Memory 8GB
Card Reader microSD Card / TF Card 32GB Max.
Screen Size 7 inches
Screen Resolution 800x480 pixels, 16:9
Screen Type Capacitive Screen
Multitouch Screen No
Screen Output HDMI
HD Video Support Full HD 2160p
Video Formats RM/RMVB/H.263/H.264/MPEG(DAT)/MPEG2(VOB)/MPEG4/WMV/VC-1
Audio Formats MP3, WMA, WAV, APE, FLAC, OGG, AAC
eBook Formats txt, fb2, pdb, pdf, epub, mobi
Image Formats JPG, BMP, PNG
Adobe Flash Support Yes
WiFi Standard 802.11 b/g/n
I/O Ports mini USB 2.0 OTG, Headphone Jack, TV-Out
G-Sensor Yes
Other G-Sensor, Built-in Microphone and Speakers
Integrated MIC Yes
Battery Life 4000mAh 3.7V
Color black
Language Multilingual
Accessories Charger, USB Cable, Earphones
Camera
front 0.3mp, back 2.0mp
Weight 319g
My mind is heavily roaming over Cube U9GT2, just ipad2 killer guest from china.
for 256USD ,9.7" inch 10-point IPS Capacitive screen Android 2.3 3.0 UI RK2918 Cortex A8 1.2GHZ 16G HDD 1G DDR3 Dual Cameras Tablet PC
looks intresting.. needs to find more real-life review video of the same.. coz sometimes the build quality can be flimsy and the battery might be powerful enough.. how many recharge cycles cna it handle..
though for that price.. it looks promising....
There are many things as FAQ in slatedorid .Also in youtube..
[FAQ] - Ainol Novo 7 Advanced - Commonly Asked Questions - SlateDroid.com - Page 4
Build quality wise ainol normally gets better stuff done .more things i will post why i choose it
