My PCB layout & PCB for Jean Hiraga 30 Watt Class A Amplifier
I feel you don't machine corners of your heat sinks. Join them by copper bars, that looks enough to me. Just remember to spread drivers on each heatsink equaly.
Machining was necessary because these heat sinks will itself act as Side walls for Enclosure and they should be in right angle or else the Shape will not be in perfect square or Rectangle. I have also made the Capacitance Multiplier, The PCB assembly already completed. Below is the Pic of it. I have not mounted the Bridge Diode on PCB.
SeBG3JVQdEGzPrW3vZM3uzvJy_hKnAekMg80ptgXVnIgwi8Xf6hEtGNmj6-1DgMGvPyXh8g4HLun2hclGzECiT9NN76hG1wNim8v7WjILVMFZzRE8j2yDrIs7Hfr7Tm0WFL4nPiQMQ_R5WgGmZxDCKyovfQBMLb7V1lIdtAM7Oua_5Wl1h_WtCx569X9TexdsOBZrsZa_CGSYdrElHY8IWQIYO7SXJsAS-5Uyrv0L7UVnbF8C3jqcX77ZHL0uRxWos3TyccNpeBf_eue_aJ4JrEsUBab7PIY1huqDKowXXl-wvY6IOx7cKkLpR3sGPIa3FwX0zry1nFbaRMzJLiaxzbZmof_89gYNOxETGYnRL-1524K3uOapLbD5_X-ngMrc5EqxlidiAWc5nB5V718H1JdkZ9kq9-uxEV6uhfvFDxjDbuyRojD_illQjRNa5LsQcqBFEAKenjxt58Pvqh9zdTApwVUnvSW_Hf-op6g6WpL8HK7j9Qpep1eWUBk5ABkmCa1UV7dxn7KFexv-7fQ9p6kbyd81RIU2_XWJe8zoJSwgeu3_r76IuXReqGByqkInoBaLuR6QeVL9rwfCAxjEcT-_ivQ2wZ0oqOxxDuo6oXmUGvM16ry=w965-h705-no
If anyone is unable to view the Pic then below is the link for my google drive.
https://drive.google.com/open?id=0B2a9DN9GbmtBWm5xY2tqT3BYZDQ
Sadik
Don't you think high current lines for input of TIPxxxx devices are very thin considering the current it will carry?
Some more updates:
Photo of Testing this Amp.
4ZgGpo4IJlIGgoT6X0gTUDJk4sEOOB9ZulG51_EQMeTMuy7tXmPYuxY2amfQDHxC5hWsZV-g6CPcpHi8hS2pjpVe4scIWNTYwKZWlHMxEGf_j_LdIKBpwa-VjnsfNhrn9GodhNjZ5dIVIRXXRxwGTYZ1vKGT03lTq6Qs1a1KMYBaFwA7oCPDZMhI6GJSO2NBI9w2r9BC5AbEQqlzlcJfbvsWuqp5wyu1p1tuLfIn1vX6AShax-iAfVoK-p61dgcmf2lI0KDw1ypWDS2IaKX64cYvv6opMGSHIyfcaGJU8ASJknJY0CtquoykZd1_xQnMYqE1ve2YoId_pOZwegBlLISbxLLQ0GbGOoqPlQlZcqsH7qofOCLKUePac5FxjnG4c4dMjI6uWgNb6UZlQPQQUrQxi-cGVCAp6wwigORrbgCdDPZAwamFAajgo_j5Sd-jQ1WnVX_EPjKifLYA9VyZy_pK53X8F6b5tRT6-HUSmggbiAb4d9yTdA_v3aURWg2-q8Z01lxLBumj2ehkqqGUt_jAKU2_R1SYuAWQ2ODgOAkelFrln8csPiIOS09l06M_Uj4pnrAhkuaYy4LBtlYdz1t3yB0xaXDsSn-GgzCCLFI6ntjv=w1230-h922-no
The Size of the Enclosure will be same as per the components placed in Photo. Now time to take the measurements and move ahead for making a good looking Enclosure.
Sadik
Hi Friends,
I have changed the driver & output transistor of one Channel, the difference was there, but I was unable to figure out which was sounding natural, hence i have recorded some music files on Mobile Phone, There are 2 files for each music samples. This files are recorded with same setup like same distance, same Volume and same song.
I have uploaded the Music Sample on my google drive, I know this method is not correct, but you can still have an idea how the Sound is. You will need to download the file name "Music Samples" from my drive. It is a zip file and there are 10 samples.
Please download the file by clicking on this link https://drive.google.com/open?id=0B2a9DN9GbmtBWm5xY2tqT3BYZDQ
Please share your reviews weather in PM or Comments. While sharing your reviews please mention the file name which you liked and for what reason.
Thanking you all,
Sadik Bhatkar.
Today's Update,
Got the Front and Back Aluminum Plates Machined as per required Size, Drilling and Tapping Done & checked its assembly. Perfect fitting. I also got the legs machined from 40 Dia Aluminum Bar, the height is 50 mm (required for good ventilation of heat from heat sinks) Slots for Connectors, Sockets and Power Switch is pending, it will be done on wire-cut machine.
Once it is done these plates will be sanded and Black anodizing will be done. For legs i will go for brownish-golden Anodizing just like the heat sinks, The Top and Bottom M.S Plates will be Black Power coated.
Below are the Pics.
sfLg3b7zJ37oT_51WenPWG1uLYxt3UR9n_4m1OgLDB4RkRjxp-sbVw5i9-8FE8d4KNoycQKS3QubJg-Xiae0B9ysoYoH0zm7KWOMYOTcxET23Wev5KkctRtqqvob_aqfryPQUKtenQotp68IikQV4HD87LB_VCVbZCjmW0sK3uj_i9sB-Ya6jfb1RKv3-FVvvNpEiFCf14gxkJyCJ6Rje30PplhAJSBGUNp__avTsikWnSXVBemSCqKwvgizw6MNREdxAD2_GpBy5NE9x8zMLRJ8m_nuKfTct9N9Wk1tlcuhOCxoMerHW1e0DKbk15Kl6duUzhXL0N4fAKXvdE5QNSLooUTqE7xM47HkDnIO7QsNwdCPz6tKWecSnwme442B4mFMdtLE4pGOGwi8Z7tVtg97HYF5xJFOWxSsGFMfSnG4CLpY5qDKnxblQcYj9vAyD1n9pgsluRFoixdAAGuGrMEZNQfjOO31Di4zJgfSF0fNe8saZBzzG-Sio4FxBvpX9EsBvhG1MLfE698iOncr2iVeKhe40M4bQbASv7L3v_2zyxiVcaWFjnEbFBesUUC7jB74oOo31JIufsSfgtT_dPQKkfzVKigUDUaDsZRuQ5stKDuGcA79=w1230-h922-no
Ko3lXemaRCcmYlvOCaSfwSj_wVl1O05zegPTmUSjUZ43yk55Ol9Tf5sFHRqxi6hF1CzuyRL6ON4pXEs1gTWA9eCaN8qu3iimI7__M0HdtRYPvZWynNGTygGLQosLRmNKmuj7zCXy121ppEAokyRt0U_pHTTBiP3uaPj23sJywDYPcQXQhWb6SvwZXXkfsR0CGVKQc-hZTBpWGsWhS_VcA27xbxPhjbqb5O3otuvPO8L5_GhhI8tle9v0PtHmPZfCkB27OESesUFfM9JRVyNnKppGPSKBKAnh6nAKc8sl06-_P79g1Gnt9HJttw8Rc31dwddCg4exrumtcoXY4OvXIm6NHhinTL8xIqUuYDSOVdzCf1in9X6PlvJoCU8Tsn_iqo5U3Tbwr-hwvWyHvs_GqlFQaiOOFehvuqmqfFh355SULoXxYGwxcAv3t3gvY7hYJ55M7PO5ESa12_NMZrj6JjOxOUHscrYZlPJlziEBKjlMIPb8rzSCrfxr1bJlVMg9ITi_w-FOmEJ6GqA7vi-k9GDrXkYaoXbmePmfTlJ7zJgs50Luh7yfdPR8GK-ii6yFiMbeqohJ5HpRUhmoZ2JufwAHPCyNyYjc1o19bZsqmHM8pvKv=w1230-h922-no
It is very slow progress, cz i am unable to get enough time to spend after this project.
Sadik
I am unable to view the photos which i uploaded yesterday. I have faced this problem in many of my posts. Is there some another server to upload the photos and will work in our form without such issues.
If the Photos are not visible then, below are the links of yesterdays photos.
https://drive.google.com/open?id=0B2a9DN9GbmtBRkdiNmtjV1NVSGM
https://drive.google.com/open?id=0B2a9DN9GbmtBOHVDREtiUmRzZXM
https://drive.google.com/open?id=0B2a9DN9GbmtBekRGM1BJalNxTUU
And below is the link of complete Folder regarding photos of my built.
https://drive.google.com/drive/folders/0B2a9DN9GbmtBWm5xY2tqT3BYZDQ?usp=sharing
Sadik
Hi Friends,
Thanking you all,
Sadik Bhatkar.
For fun i downloaded the music samples. here is my take on it:
preffered files
Sample2-1
Sample2-2
Sample2-2-2
Sample2-3-1
All above are a bit louder it seems. more presence and punch.
The others seem very distant and echoed. :indifferent14:
I can't see them either.
Try imgur. So far it's been working well for me.
preffered files
Sample2-1
Sample2-2
Sample2-2-2
Sample2-3-1
Thank you very much for your feedback, I too liked the sound of Sample2, The vocals are also very clean and they don't get mixed up with other frequencies. Yes you are right it has more presence and Punch.
Very nice work Sadik. I heard the music samples. I liked all Samples named '1' . Sample 2 sounded clear but little bright to my tin ears.
regards.
regards.
Thank you very much Hiten for your feedback... This helps to know the taste of music for different peoples...:)
It could also be the gear used for listening.
Sent from my HUAWEI P7-L10 using Tapatalk
Yes thats absolutely right. I will try to listen in proper setup. But one of my DIY speaker is dismantled. I have the files will hear again in few days.
Regards.
Further Updates:
Got all the Parts needed to assemble the enclosure
KIF-zo2IT-m-mKrQDtmPempdfC2dyz4VN69eWMuqewHC0e0U-JA5uEfKlCouahjbx97Hjhep6y9unqagRQDpz-CHcE_7LhaSNCz9QkgiwE8wp6p0SD4C7_UeNGOAGwTkO7QgTHniplpD4Ppr7FFhMWV9PX9gxKfX-DXIIDCl7xGRQoMvcrNQgo6uKH1vBec9KPZttRNmdI12h2_pt-SnTbNrqe3SJdMt8ksMCdkFKVwygeopZ_zKWDZHGhYKnWd3EVhWjHJ7yNT1pkNzWAAxfDdSIT7m2VwfBORWzWLrn61Ag7uNQps-zISnePYgS-rj4EDgrdVdVJVlWDLwpeW5bsgwSH9U6Z1DqZS78QSxFddSwonDP2IGhkSlmwIIfkhKRFxHh34NfypiLRJalc4pX6Syek29Jvp43gEegqkU3JN8YKbZS6aAkjQ5azjOl6Y5TfvGPe4C7gypfi4HQ5dbg0iERaAuEqpCK6B0OXvi9OgaJ1Q7_PTwgmuhE6CnZoXaIXmJu4xd6xobZSXedTjJpR66aRvt7SYD0ozPsBqP9RYh9MAMor8Q54gtzMNNodsms55KJJShm0OlaTsBLU4WCEAdnB9giKCfJ1-jDoHlPz8B__B7GnF5=w1230-h922-no
Feets / Legs :
XgIqMhXIqPPjrhlV2lC7EcJcMizu-W0LR92tF9GSyb0ojFHe-YxQMcz2PC-INDU5E1SEiwUGSIgLSSBPpQV3kkpqqj3mKKwIFDZkzPeSgj_KcO_IKjJ5feWr55PtwuBNSYO1_ThkreTYiq5FtWe6IbrucykcLyaOzCg7nNE-Jfyj0bhnKcA7c-FwrkyE_bjzZZMlj5ptaGr7mmz-bdem5hKub7wvJISfbKG1GMmwkcpo2kaxUbUhWE_24IHF2FSfCiUoZwTO-DbVFxuVVjfmDB2czZli24h2xLJVDAL2J0QTCLyjLOWq55E2NGtyY8ijwAdNg0FbPcIV6r6E7bVSpV59HTdX8WVxjsAkb-EHy2xfzej77K0fxGMO-GcHguP5vMc9R3gVpEqXOIqgRa7ylWjiq0LrLPaEMbtnpGXkhmt88SH0uNNJFcX4Ht0NVGj4EGqcEuY-rHDi0DCwTa_wLotbvCHf6TpT5lTeWZyrAkenZ2Fszdgz7lZ5_2l_Qox_zOGiPPWrxxVj7Z_6UhZw_ogydyAmxtT24kn6m1IS3ZOi6ubjmm4VXbA8g72pMlarRpn10iucE6CoVWVpmMbWFWYVeD-8wUvWmFvdaM2P0CG6uzIk=w1230-h922-no
Back Plate:
6RdIovMcoVbBCrgtbbSl-kfPmn0OejiApPK1HXLwiVTeseSY1V5d7KVeNN4s7DfKR4CuUs9UVosNnZ4990MN5pQvpNvz4HC96qn1CfC4xMiXzIVSokFVf84BE2pJQfjUi1Ns8nt1Cpmat6luIOntFwKbCd4D-pclfwtpLng_isL7vIt7KWAM6Pff_t6MZwjkpfVbqHYGrcVLx8d-feQ4FKv_ebRAsPqAGtOVrDD-0nwmbBKj6RE7p4KkAuQaTW9asCXOralG5bobNWctBTmKJkv9Vli0BaH2PmT7H-YhBODHf9eVPCAPJm29Y2zf7u1OJ7-X0_s-Z9_07wakAQZWCfsIWzBefmi5mpWkk2pkSyczC6Aa7oTnNAFVmIdJvsFXUkZt2giO6luWSDx6jDZ0CWiqlMB2wwd-8TwN3sxlAqSrcVq9KorbYLAPpJX_gyJYpD08el-2STRIwBF7cWeItq_UrJdrnSytYGZz_tMnWt_iAkX0e6GbxmlxvhwjSbcUhSzWOV9md1EdVLE1MhMNjZ7IOTKO30GcXvJg4b6iIBO3NtRicqBR4Ir5m1Y9Cr8I3AgCQ0oD_TbAM7V4MSNQCPOm_2qNJalUVtetOgLDeNLc0s1A=w1230-h922-no
Those Speaker Connectors & Mains Socket Cutout are done on wirecut Machine, You can see those Speaker Connectors cutouts are somewhat like a "D", Its to lock them so they wont slip from its place.
Front & Back Plate with Switches, Connectors & Sockets
pLjNRRAaNs36l7jC9aDG6MTVt-Pd4VK2i6UhSML5hJcFqfHT2knqXzlc6zZN2dDBWSj5ElfvTS2oyB-nUqnFWZKrdkVec3spquHenQ8Mgt09nmA1J5ZlSSF14KflE-uo58fKlfgBTFRKoIHXhR2it349lChJjZcCXD-nLXDyEdIW668objyCcFFTwwIbukc2NRe3jVSHNuNyxPNsznMZWm8y0HaG6GtyE9POL1YERIbadJVBpwsK0wtDfPqHZkiSkcjMVfOiIZ9-avSYZqyAATcVti6GQ5AywyPLVlrZK-kIIzV3SLDZyupw2jhG5yevV1JKlIPIFakdfBXPedgO7ERWfX9JjxOOoW3baAGigjDTlV_GJUMHX6uRxY8otk4od4UfWthI2XYpYFmhl7VDtBzGoy4Op-UF7cHDo5l3B5hauCRk2-6FG93DlMCvvUG-z-HWdErRp2Mn50FcfuBCcRAg8GfYCA_4N74ykh_zw1FT9jvIZUfmOmJ3SuRmOLj6VR9Fbu6eF--EMJVKMVA5SJ0dmEMfswcyjZsAp7YD67_ZST9kdYe_X7f-5IBXD5vChkb8p49DHLFZldAVOuNSR-TtWMK4ji9CqjXoZZb3p-900nRe=w1230-h922-no
If unable to view the Photos here is the Link for my Drive Folder
Now time to Assemble....:)
Sadik
