need advice for home theatre buying
u will require a media player which will support lots of video and audio formats...
Guys correct me if I am wrong...
Infact me myself in search of a media player
My requirements....
plain and simple .....it shud support all the video and audio formats:)....
I dont intend to use internet on the same....jst need it for watching movies with my Home theatre...
Can you please suggest one for me.....
There are many media players to choose from. If you don't need frills like networking, internet etc. then look for Kaiboer 1055+
Kaiboer H1055+ HD TV 1080p Media player 3.5" HDD bay | eBay
If you want more advanced player then look for himedia hd600a. There is a dedicated thread for himedia and many including me have placed order for himedia players.
http://www.hifivision.com/media-streaming-players/18774-himedia-hd600b-wd-tv-live-india-pune.html
Media Player Box
My setup 2TB HDD via USB to Asus media player HDMI to Onkyo 3300 HDMI to Samsung LCD, B.Ray/HD recorded on H Disk plays well in 5.1
Thanks Baiju...
with this link it really do seems that there are lot of options......
Which one do u all suggest...
Kaiboer, Iomega, Asus, WD ,Miccaor Himedia.....
my only requirement is it shud support all video and audio formats..and I shudbe able to connect it to my HT....
Thanks Baiju...
I will recommend kaiboer or himedia. The others can't decode HD audio formats. I have placed order for himedia hd600b. Himedia comes with HDMI cable where as with others you will need to purchase HDMI cable separate.
Before deciding on a player, please think whether you need network capability, internal hdd support etc. If you buy a media player with internal hdd slot, you can fix an hdd inside the player and dump all media files in it.
Thanks Baiju,
I am almost decided on Kaiboer....jst one question....
difference between Kaiboer 1055 and Kaiboer 1055+ only seems to be is that plus has a hdmi cable and case for internal HDD...
Correct me if I am wrong......
As I have hdmi cable already....also wont need Internal HDD bay....so might as well go for Kaiboer 1055 saving me 900 or so....
Thanks Baiju,
If you don't need internal hdd slot then buy 1055 and save some money.:)
GOT my HT 3400...Kaiboer Media player....and panasonic BDT110...:)
can someone help me with Level cal function of AVR..wht DB shud i set for the speakers....
