Hey guys,
I'm building a new HT from scratch and I started by looking at a Polk soundbar called command bar, and soon with the guidance of a friend, graduated to looking for true-HT systems (I was initially shying away from wiring up the place and hence leaning towards wireless stuff but once I bit the bullet, wiring for a 7.1 setup doesn't seem like a big deal anymore, given that I'll enjoy great sound in the end).
In the HT land, I started with YHT-1800 and soon the itch to cover more ground in terms of features & future-proofing took my budget from 30K INR to 80 INR. I'm now looking at entry level Atmos systems. I think I'm now ok until 90-100K but don't want to go beyond that.
Among AVRs, I have recently looked at Yamaha RX-V585, Yamaha RX-V685, Denon X1400H and Denon X1500H.
I'm now mostly hung up on either Yamaha RX-V685 or Denon X1500H (both around 55-57K INR).
I've made a list of pros/cons of one over the other and here it is:
Things Yamaha 685 does better than Denon X1500H
Denon X1500H better than Yamaha 685:
I'm close to picking up Yamaha but don't want to rush and reject Denon without giving it due consideration, especially since all the good reviews I've heard.
Can fellow members guide a newbie like me into picking up the right system? Is Yamaha better in terms of service & repair in India (esp. Pune) compared to Denon?
Cheers and thanks in advance guys!
PS: This setup is for a 10' X 12' bedroom. For speakers, I'm thinking Taga Harmony TAV-506 v2 and getting 2 more satellite units from Taga for the atmos ceiling mounted units.
I know there's another direction of suggestion to build the system overtime and invest into really good speakers slowly as budget permits. However I think these should be good for the bedroom amd the ~2-3 hrs of movie/TV usage everyday so I may not upgrade these speakers ever. If there's an upgrade itch later, I may go for a more high end system a few years down the line for the living room, but as of now that seems unlikely to happen.
- 2 HDMI out instead of 1
- 90W/channel vs 80W/channel
- 4K upscaling (don't really need it)
- Multi room Playback from Digital Audio Inputs
- More audio-video inputs as well as more audio-only inputs
- Extra connections on the receiver to connect zone2 or Front presence (9 speaker connections instead of 7). So I can wire up 7.1 + Zone2, and use interchangeably.
- Bluetooth in as well as Bluetooth out – This receiver can be connected to Bluetooth headphones which is a nice feature.
- One more hdmi input (6 inputs vs 5 inputs) : dont really need so many though
- Google assistant support (Alexa support is there in both although how good it works I don't know) This may come handy in future.
