I controlled my urge to get my first set of speakers and after multiple auditioning, reading through multiple forums - I had my choices of floorstanders to begin with - Fyneaudio f303 was my choice. Meanwhile planned to discuss with Sonicarchitect to get an additional Bluetooth or monolith speaker for my wife. Though my discussion with Sahil started on that note, I also happened to discuss about the floorstanders plan which I predominantly decided to be a 50/50 for music and movies. Our discussion went on for few months, all of them were longer ones and meanwhile I listened to multiple recordings of his previous speakers in that period. I got more confident with his work and decided to let him make his/my first pair of towers. So far he has made only bookshelf speakers and monolith ones.
He suggested he can build one very similar to Sibelius SG/CG from Pearl Acoustics, I also decided to go ahead and gave him the nod. My only concern was the signature shouldn't be bright as I am into warm signature and bright fatigues me much. I explained him the same and also informed him the bass should be tight and quick, not to be boomy. He assured me to make one to my taste.
Just like Sibelius SG, he went with Markaudio 6.5 inch full range gold driver and is currently building the prototypes for my tower. He proposed to make two different enclosures, and record the sound. Based on that we decided to figure which suits to my taste. Once the prototype is fixed, he'll make the final build and it will be of complete teak.
He'll be recording the prototypes with a A/B amp he sourced and suggested he can get one for me.
I am going to use it for both movies and music, for time being I will stick to the towers alone, might add one or pair of subs for movie experience. But down the line decided to expand it to Dolby Atmos setup.
Now the thing is, I have few doubts -
1) should I go for an AVR at the very beginning?! Or an Amp will do fine?!
2) If it is an AVR, which one will be good?! I was trying to get x4500H or x3600H somehow or should I go for equivalent models from Marantz. Do suggest other options as well.
3) If an Amp it is to begin with, what would be the ideal choice to start with?! I am juggling between the Amp he would suggest and PM6007 for time being, as Marantz would be warm and musical to my taste and can also be paired with an AVR in the future if I go this route. But confused whether it will pair fine or not.
Note: Sahil suggested I might not need a Sub as the towers will suffice enough Bass required, though I will decide it once I receive them as movies will also be option of playlist. But I also have plans to go all towers route and get them made from him. Center alone will not be a tower, but will be having a markaudio driver of similar signature.
Every possible suggestions and plans are welcome here as I will read and research from the inputs I gain here.
