New amplifier recommendation
hardcore_gamer99
india
Previously i had x4800h with dali opticon 2 mk2. Now again i have bought x3800h. Which brand of amp should i buy to make dali sound warm neutral. Will add opticon vokal as well later.
Marantz MM7025
Rotel RB-1552 MkII
NAD C 275BEE
Use X3800H pre-outs → external amp for front L/R
Let Denon handle center/surrounds
This gives better stereo performance... frees AVR power → cleaner overall sound
You can try adjusting the Multeq curve in Audyssey and make the tone warmer.
still i want to take load off the avr to amp. i have dirac with bass control and ART
If you have a sub, then a lot of load is already taken off the avr.
Besides if the room is small then the fronts have enough power since your surrounds are not continuously engaged. I am content running an avr with a 5.1 HT setup in 14ft X 11 ft room size. But if you feel that you need a power amp since your avr is being overloaded then there is a recommendation above.
i heard its not only about load. Does amp not enhance sound? Room is only 13x10
but all amp brands have different signature? I am looking for the best for dali
Its the pre amplifier that controls the sound
The power amplifier is supposed to only supply as much power as the speaker demands
It is not that the amplifier pushes power into the speakers
It is that the speakers pull / draw power from the amplifier
As to the best for Dali speakers...each series of Dali will have its presentation
Best to try and buy
Good luck !
And by the way.
On this site I get a pop up about O&B amplifiers
Why don't you try it out ?
Talk to them if they will help you with a try and buy or some other commercially workable deal for you
In fact talk to a dealer near you and maybe you may land up with something nice
