hardcore_gamer99
Dirac live activation keys.Oh nice! What do you distribute ? Bass control free is cool
What do u suggestYou are making a lot of rushed decisions without thinking things over.
What was the point of selling a capable receiver like the 4800h and looking for another "like one" all over again! I suspect you lost some money on the sale of the Denon and you are looking at spending the money all over again. Likely more. Makes zero sense.
I get that you needed funds but now you are losing it all over again.
Buy something cheaper and make peace with it. Its freakin audio gear after all. If you can't buy it today, you can buy something else tomorrow or later, when funds are available.
Honestly, I do not think I can recommend anything. I don't know much about your speakers, what they sound like. The specs suggest they are power hungry and need solid current. Am actually surprised your 4800h could drive them.What do u suggest
as said i sold for money i had only 2.1 setup. I can get emotiva a5 but will not power be shared if i connect 3 speakers to emotiva? How to see it will enough and sound better than connecting directly to denon.Honestly, I do not think I can recommend anything. I don't know much about your speakers, what they sound like. The specs suggest they are power hungry and need solid current. Am actually surprised your 4800h could drive them.
Someone already made a suggestion, get something like the Emotiva Basx A5 and link it to the pre outputs of whatever AV receiver with pre outs you can find. You'll need to forget about Dirac and Atmos for now. Again, not the end of the world. You seem to want everything yet you don't have the funds to support that. Cuts need to be made. Or, just wait till you have the funds.
I am now getting x4800h at 1.30 . Is emotiva good brand?The Denon x4800H was available at 50% discount at most dealers. You can get the X3800H at 1.05 lakhs and get a PowerAmp for the Dali Rubicore series since they will need more power being 4 Ohm speakers.
If you are getting power amps then go for 3800 and not 4800 and save someI am now getting x4800h at 1.30 . Is emotiva good brand?
Will try marantz this time cinema 50If you are getting power amps then go for 3800 and not 4800 and save some
Audition first since marantz is slightly soft|subtle for movies. AVRs like Denon , Pioneer, Yamaha may cater better to movies.Will try marantz this time cinema 50
I want music as well. Soft means?Audition first since marantz is slightly soft|subtle for movies. AVRs like Denon , Pioneer, Yamaha may cater better to movies.
I don't understand your question around sharing power.as said i sold for money i had only 2.1 setup. I can get emotiva a5 but will not power be shared if i connect 3 speakers to emotiva? How to see it will enough and sound better than connecting directly to denon.
I dont want to waste single penny this time, So i can get cinema 50 If this emotiva can drive easily dali rubikore 6+ rubikore cinema
Ok . If its 5 channel. If i buy 2 channel for floorstander pair and another for centre speaker only will it not sound more clear? Or 5 channel amp will do with same sound clarityI don't understand your question around sharing power.
Its a 5 channel power amplifier. It does not share power between channels. Thats more in an AV receiver. The less speakers you drive, the more power you have available for the ones connected.
If you don't want to waste a single penny, then you need to do your due diligence. Carry your speakers or get the Receiver, PA home from a Dealer for a demo and check. There is little use in asking us whether it will sound right. Thats up to you to figure out.
ok i am very much new to amps never used thats why confused. Thats also money saved with 3 channel. Arcam is made in usa i guess will it be costlyI see zero benefit in this.
Its 5 channels, each with their own dedicated power amplifier block inside. The power is not shared between channels.
Or buy only a 3 channel amplifier. Power the front, center and right with this. Thats where the most power is needed. The rest, drive via the AV receiver.
You may not necessarily save money with a 3 channel amplifier. Some can cost more depending on power output.ok i am very much new to amps never used thats why confused. Thats also money saved with 3 channel. Arcam is made in usa i guess will it be costly
ok thanks i am done with cinema 50 . Now what what do you suggest for amp brand and power rating? Dont want to lose sound quality it is priorityYou may not necessarily save money with a 3 channel amplifier. Some can cost more depending on power output.
Arcam is British. I doubt if they are Made in USA.
Quality comes at a price. You can't play the game of "cheap" with audio. If you do that, well, you're going to hear it in the sound as well. You don't want to cut corners with the loudspeaker you have.
You can consider o&b poweramp alsook thanks i am done with cinema 50 . Now what what do you suggest for amp brand and power rating? Dont want to lose sound quality it is priority
Check Emotiva. I've already shared some models and some other folks did too if you scroll upok thanks i am done with cinema 50 . Now what what do you suggest for amp brand and power rating? Dont want to lose sound quality it is priority
i am getting x4800h at 1.35 and cinema 50 at 1.28. Denon has a bit more power and cinema 50 made in vietnam as well. But really want to try marantz this time. If use amp then that little more power matter in denon?Check Emotiva. I've already shared some models and some other folks did too if you scroll up
Outlaw Audio is another. I don't think you can demo one
Rotel
Too many to list here
