OPPO has come out with a new CI BD Transport:
https://www.oppodigital.com/blu-ray-bdt-101CI/blu-ray-BDT-101CI-Features.aspx
Advanced Features
Universal disc format support including Blu-ray, Blu-ray 3D1, DVD, DVD-Audio, Super Audio CD, CD, HDCD and more
Upscaling to Ultra HD (4K) resolution
VRS (Video Reference Series) ClearView video processing
Dolby TrueHD and Dolby Digital Plus decoding
DTS-HD Master Audio decoding
Bitstream output compatible with Dolby Atmos and DTS-X
Three USB ports for playback of media files2 (AVCHD, MKV, AVI, MP4, WAV, FLAC, APE, DSD, etc.)
Ethernet port for BD-Live, firmware upgrade and home network media file playback
True 24p video for Blu-ray encoded in 24Hz frame rate and optional conversion of DVD to 24p
Multiple zoom modes
Advanced picture control including video smoothing, detail and edge enhancement
Premium 32-bit audio DAC by AKM
Optical and coaxial digital audio outputs
Rigid steel chassis and center mounted disc loader with motion balance and vibration isolating mechanisms
Back-lit remote control
Custom Integration Features
Versatile modular design with many customized options
One or two HDMI outputs via the additional HDMI output module
Optional HDBaseT output module for long cable runs
Stereo or optional 7.1ch analog audio output module
Optional rack mount kit
Large front panel buttons with finger guards
RS232 and IP control for system integration
Switchable rear IR sensor for a clean IR blaster/emitter installation
HDMI CEC (Consumer Electronics Control)
Three customizable picture adjustment presets
Settings can be locked to prevent inadvertent changes
Understanding the Differences between the BDT-101CI and BDP-103
The OPPO BDT-101CI is a reliable high-performance Blu-ray transport designed for custom home theaters and professional applications. It shares many features of the BDP-103, BDP-103D, BDP-105, and BDP-105D models, yet there are some important differences between the BDT-101CI and BDP-103 series (including all variant models):
1.The design of the BDT-101CI focuses on its core function of disc playback. It does not have Internet streaming apps or inputs for external sources. The BDP-103 series is composed of full-featured universal Blu-ray players with Internet streaming apps and HDMI/MHL inputs.
2.The BDT-101CI features a modular design that can be customized for each installation's unique requirements. The BDP-103 series does not offer modular customization, and each model comes with a standard set of features and performance specifications.
3.Because of its highly customizable nature, the BDT-101CI is only available through custom integrators, installers, and local resellers. The BDP-103 series can be ordered online directly from OPPO Digital or other retail channels.
Our recommendation for choosing the BDT-101CI or BDP-103 series is based on how you intend to install and use the player. If you need a simple and reliable universal disc player, the BDT-101CI may be a perfect fit. If you need a player with additional features such as network streaming and external signal inputs, the BDP-103(D) or 105(D) might be a better choice. If your primary use of the player is for listening to music and you will connect the player to high quality amplifiers and speakers, the BDP-105(D) is our recommendation for audio playback. Should your particular installation call for long cable runs, the BDT-101CI with an HDBaseT output module can get the job done.
Advanced Features
Multiple zoom modes
