New Sony 65X80J - flickering and ghosting
argho
Chennai
Hi All.
Just moved into a new apartment, and have bought 2 TVs.
A Sony 65X90K - for the living room
A Sony 65X80J - for the bedroom
The X90K is working perfectly. Am very impressed by it.
The X80J is suddenly showing very bad flickering and ghosting (this is 1 - 2 days after installation).
I have raised a service ticket with Sony and am waiting for a technician to visit.
Meanwhile, have tried everything I could think of (to no avail) :
- Unplug and plug back
- TV self diagnostic
- Disconnected my amp
Cant think of anything else.
Any suggestions ?
Hi All.
Any suggestions ?
Looks like an issue with the panel, they might need to replace it.
I had similar issue with my Samsung TV in the past .. the issue was with the display board, After replacing it worked fine.
Mine was almost 8 years old TV , Since your TV is new .. problem may not be the same.
As you have raised a ticket, I'd not meddle with the TV. This is Sony's problem to sort. Their technicians are usually the competent variety but could vary depending on region.
You have a warranty so no cause for concern.
