Newbie:need advice for custom made entry level HTS
Thanks efernand1 , I will surely do the audition but I am not a audiophile , all the bigger speaker sounds good to me. But I will go to audition .
Can suggest some place in Delhi NCR ?
I have heard Indian brand sonofynr is quite good
Sent from my Mi 4i using Tapatalk
Hi, you can audition some good sets of bookshelfs and FS at Sound by Design, Gurgaon. Sid is a close friend and you can give him my reference.
My name's Utsav.
Also for Yamaha and Onkyo it really depends on auditioning and what kind of audio preference you have?
I need for movies and 1 guy suggested that Yamaha 579 is quite good no idea about onkyo prices I have already posted so my budget for AVR 25to 28k
Might be a silly question.
Is it good to use active/monitor speaker for surround in HTS
Like klipsch R15-M. Or Audio engine+?
I don't have much idea , so looking for your advice
I have seen power supply plug at the back side of R15 , so it require power to ON?
Other Boomshelf also require power or just attach cable with AVR works?
I am.a newbie, so looking for option , currently in hong Kong and bookshelf speaker are cheap here as compare to India market R15m is around 19k so looking for advice can I use in HTS ?
BA A-25 also around 9k
Pls suggest some other speaker for surround
If you are in HK, get few markaudio alpairs. You won't get any branded speakers at that budget.
But I am getting branded pair ,
Like BA A-25 9k
Klipsch R-15M ---19k
MarkAufion is better than above brands?
Like BA A-25 9k
I believe they are. You just need to get the enclosures done. Alpairs are raw drivers.
Sent from my Nexus 5 using Tapatalk
You mean I need to make cabinet ?
I can't ...can you suggest me some good bookshelf speaker for surround?
Front and center thinking to buy Polk 440T .
I am confuse about AVR also I am getting pioneer vx 930 around 27k
So thinking to go for Yamaha 579/679 or pioneer 930/1130.
Looking for your advice
