Norge Symphoney Vs Millineum Bookshelf Speakers
rajat071
Hi All,
I am planning to Bookshelf speakers, the Amp I have decided as Norge 1000 Gold.
So now have a choice between Norge Symphoney Vs Millineum Bookshelf Speakers.
has any body in this forum had a chance to audition Norge Symphoney BookShelf speakers. I am planning to buy them but don't have any opportunity for their audition here in Bangalore.
If anybody can share their listening experience on them, that would be a great help for me while taking this decision.
Symphoney Reference:
http://tech2.in.com/india/reviews/bookshelf-speakers/norge-symphony-bookshelf-speakers/48581/0
http://www.norgeaudio.com/oct_08.pdf
Millineum Reference:
Tech2.com India > Norge Millennium Bookshelf Speakers > Reviews > HiFi & TV > Bookshelf
Norge Audio
Here is their specs,
Norge Millenium Book Shelf - 15000 Rs 2 Way, 1 driver 6 x 1 silk dome tweeters, 125 W RMS, 4 ohm, 40Hz 30KHz.
Norge MD Symphony Book Shelf 15000 Rs 3 Way, 2 drivers 5 x 1 soft dome tweeters, 120 W RMS, 4 ohm, 30Hz - 23KHz, 90 db.
My requirements are,
1: I will be using it 80% for Audio and 20% for watching movies.
2: I listen to almost everything which I like at times, right from Indian Classical(mostly Santoor and Tabla), Gazals and soft vocals to fast hindi movies tracks, Panjabi, dance numbers, Pop, Jazz etc. So basically a setup should respond well in all the ranges(low mid -high), and posses tight and enough bass to fill a living room.
3: Currently not planning to go for a sub-woofer.
5: Would also like to play radio/FM etc.
Can somebody please share his/her experience on the same.
Thanks a lot.
^ they are(were) defineltely cheaper wheni reveiwed them
i think the model was md 75 or something
Yeah...but the norge speakers which Magma reviewed, 3 Way Symphoney wasn't there among them :(
However I had a long discussion with Magma over phone, and that was awesome. For newbie like me it was a great learning. He explained me the basics of a 2 channel stereo setup and listened to my novice queries very patiently. Thanks a lot bro.
And about the pricing, The 2 way Millennium are available at 11,500 where as 3 way symphoney are available at 15,500.
for a 15 k budget i would look at PSB alpha B1 quite seriously
do look at those
unfortunately no one here stocks the symphony for me to review
and i dont want to impose on mr bajajwheni have no intention of buying
