Objective 2 Amp help !
killerpayne
Wanted to caution you ... Do NOT plug in the AC Charger unless the 2 Rechargable batteries are connected !
Without the batteries connected, the DC voltage could be very high .... potentially damaging some of the components.....
Thanks for the heads up.Everything is working fine as of now.
I used a hot screw driver to punch holes in the plastic.Looks shabby I know
Maybe, but I'm doubtful that I could do much better! :) On the whole (no pun intended :o) it looks good.
There may well be more appropriate threads, but many of the HFV ODAC buys made their own boxes: check out the ODAC DIY thread, you might find it useful.
Thad, you are correct .... My bad.
I checked the Ckt diagram. The DC is regulated by 3 terminal regulators, so no concern at all, even if the batteries are removed and the Unit run off AC.
Please disregard my earlier caution post ....
IndianEars, I can't even read a circuit diagram. I just happened to know that about the o2/ODAC :o :)
If I should ever get the chance of having a soldering lesson from you... :D
Many thanks :)
Maybe one day, but out of the other metros so far I've only made it to Hyderabad and Delhi, for one brief visit each.
