opinion required
jini
mumbai
hi friends . new to forum . needed advice . need to know the av receiver to go with whaarfedale diamond 9.5 , diamond 9cm . have short listed pioneer 1021 and yamaha 667 . have any one auditioned the two receivers . thanks .
hi again , can anyone guide to best receiver which matches with wharfedale diamond 9.5 , diamond 9cm , wharfedale powercube 12 + . thanks
Can you post what your budget is? Only then can other members make informed recommendations.
Both AVR can go well with Wharfedale.Yamaha 667 can be little better.Where are you getting 667 in Mumbai & price?
only thing positive about yamaha 667 is discrete amplification of each channel while in pioneer 1021 there is a single integrated chip which amplifies all the channels . pioneer also failed many upscale lab test of scaling and deinterlacing ie jagged test shown in hometheatre .com website , but interesting thing is pioneer 1021 mid range av receivers is recommended by most reviewers ,even by hometheatre.com . any ideas on this . rest all features pioneer beats yamaha . well i am not an audiophile and this is my first home theater set up so any information from experts would be welcome .
Sad part is you don't get to audition everything you want . most sellers have denon av receivers in their audition room .
still I have not sorted out where i will be buying from and at what price . but i have checked on amazon so i know what price to expect and give .
Denon 1911/1912 work pretty well the Wharfedale's as well. However the Yamaha 667 would be a better bet
IMO look out for AV receivers which have preouts.
In the future if the upgrade bug bites u and decide u need to give your speakers a little more juice, you can always add a power amp and free up your AVR's job to power the surrounds and processing
In a way you are future proofing your investment for a couple of years. why chuck out an AVR 2 years down the line for the want of power when u can simple add another component to give your AVR a boost.
- F l a s h -
DENON all the way...............
Thanks to Flash and aakashr . pioneer has come out with new model 1121 . any ideas on that . have any one combined wharfedale diamond 9.5 with pioneer av recivers . i am more inclined towards pioneer as they are loaded with lot of features . any suggestions .
thanks .
