Can we use External HDD 2TB with Optoma HD141X directly and watch movies? Actually I am planning to Buy a 2TB HDD for storing my selected movies.
Please let us know your views.
Wouldn't you lose out on the audio?
Hello Friends,
Any one using this PJ for 120 inch diagonal screen size in 16:9 format?
Can you please let me know the distance from Screen from the projector and if mounted from ceiling the gap between the ceiling and the pj?
Any one tested the Super WIDE OPTION... ?
Samrat
Hello Friends,
Samrat
As per following calculator, for 80", throw distance is 9ft.
Optoma HD141X Projection Calculator - Throw Distance and Screen Size
Can I increase the throw distance to 11ft, still use 80" screen?
I tried zoom out (reduce zoom), but i see picture reduce size, but gray shade in outer area.
Any way i get whole image perfectly as i see without zoom option?
 hyeah:
hyeah:The ideal thing to do is when you setup your screen, position the Projector at the appropriate throw distance to get the desired screen size.
Normal procedure is
1. Check the amount of Throw distance you have in your room
2. Based on this check with the Projector model, what screen size you would get given your rooms Throw Distance.
3. After this you can decide whether to go in for a Short throw projector or not.
4. Fix the projector in the appropriate location which gives you the best screen size with minimal or no Zoom adjustment.
Ps: In my case I wanted a shorter Projector mount, so I ended up cutting the extensible arm and fixed ithyeah:
Hi Friend's,
The invoice which is attached on the face of the envelope indicates custom value as Zero. Inside the envelope amazon has sent only the invoice where the product price and freight charge's are mentioned.
IMO.... just send this note (where custom/import duty is showing '0') to Amazon and directly ask for refund instead of asking proof of how much duty was actually paid, you may be lucky and get full refund
Hi Friend's,
Today evening I have received the parcel from DHL having Optoma HD141X along with a yellow envelope containing the invoice. The invoice which is attached on the face of the envelope indicates custom value as Zero. Inside the envelope amazon has sent only the invoice where the product price and freight charge's are mentioned.
I have prepaid custom duty of around 13k at the time of payment to amszon. I have contacted DHL for duty paid receipt but they told me that it will be given to shipper I.e Amazon and Amazon will give it to me if requested. I need to know what exact amount has been charged by our customs.
Does anyone faced such scenario ? Should I ask Amazon for duty waiver?
Pls do advice.
Rgds,
Samrat
I am new to this forum..dont know mych about tech issues
i have been reading this thread...I want to buy same projector from amazon.com
but when I place order ..it didtn ask me password for payment & it shows " your order place successfully ..& then says " your order canceled due to decline of payment..i have checked my bank..no issue from them..& its internationally enabled debit card..
does anybody face same issue..please guide me..what to do now?
thanks
Congratulations...Hi Friends,
Exactly after 2 months Amazon.com refunded my Import duties. Initially the customer care guy was reluctant but finally done by some Senior.
Samrat
