Panasonic RF-800U
jsbhavsar
I recently brought one Panasonic RF-800U portable radio from Dubai. A close friend brought that for me. Radio works on 4 D size cells. it also has 6V DC 1.2A input.
Very unhappy with the performance of the radio overall. The radio does not have external antenna (aerial) ports at the rear for AM or FM or SW. AM is extremely noisy in Mumbai flat system where we actually live in a wire mesh (all flats in high rises are wire mesh).
The other radio I am eyeing is Sony ICF-J40. works only on battery and has no 3V DC input port. I believe it has a external antenna port at the rear.
Both RF-800U and Sony ICF-J40 are not launched in India. They are only for select geography.
Any easy way to suggest a tunable AM loop for the RF-800U radio with a 365pf variable?
Please help.
Hi, I had a similar experience when I got the Sangean PR D5 which has the biggest ferrite antenna among handhleds - 200 mm but it failed miserably to pick up signals. Fared worse then our old Sony. Even the Grundig field radio that we have doesn't work well for AM. Guess its not justified to expect radios to pick MW nowadays. Try SW those are resistant to the EMI.
BTW I have the D size cells that I got to test the PR D5. I completely forgot about them. They are lying useless, if you want I can courier them. Let me know.
Please help.
It’s not easy to select radio set and tune it as per your interest. Go to the terrace of your building. Find some old TV antenna. Hang wire to dipole. Bring it from window to radio antenna and attach to it , now tune same Panasonic 800 u which I’m shortly going to get. This will solve your problem. Reply me here with your experience.
I had been a regular radio Dx'er in the old times and have used various radio receivers from valve to solid state and from home made to commercial ones. I gave up the hobby long ago and started to focus on music but the experiences still remain in memory :)
Here are some of my thoughts:
Any radio built properly and calibrated properly, can pick up regular radio stations on the MW (local), SW and FM bands. For long distance reception, you will have to use an external aerial (even for MW as the internal ferrite rod antenna wont suffice). FM long distance is very tricky as you will need to use a higher gain antenna (preferably yagi) and go higher with a mast and even better still with a low noise mast RF amplifier (called booster in India)
In the old days (well upto the early 1990s i would say), the major source of interference used to be fluorescent tubes and during festival times, people used fancy lights worked by starter-bulbs which caused irritating crackling sounds on radio and even on TV. I fondly remember the motor-boat sound on shortwave when an autorickshaw would pass by our street. One could get away with it to some extent by plugging the radio into a mains socket which was furthest from a fluorescent light and by using a good but dedicated earth connection.
And then, there was a band full of radio stations in those times, transmitting on shortwave and medium wave frequencies
I had used long-wire external aerials all along, made of galvanized wire of around 20 odd feet tied high with insulation, between 2 coconut trees usually, about 30 feet over ground level.
My last radio receiver was the great Siemens handheld 10band receiver, RK 621.
The situation now is rather different. With CFL and LED lightning dominating these days, the levels of interference has simply shot up. There are new appliances like induction cooktops and microwave ovens that contribute. Although FM is not so badly affected, MW and SW are severely impacted. To add to this, there is more RF around - cellular phone towers, wifi, etc
Most of the big world broadcast names have either discontinued their SW transmissions, reduced their coverage or reduced the length of their service daily. Srilanka used to host a number of relay stations for all the big names but all these have been shutting down one after another. Most of the radio stations have simply moved from SW to the internet.
I have not used any of the modern radios but i would assume that the focus is more on FM these days. Not sure about how many people listen to AM radio. A week ago, when waiting at my son's cricket coaching venue at around 6.30am, i tried manually tuning the MW band of my car's radio and was pleasantly surprised to hear Tirunelveli, Bangalore, Hyderabad and Chennai stations of AIR, apart from the local and powerful Trivandrum station. I did notice that by 7:30am, only Trivandrum could be received and the rest disappeared.
Regarding connecting aerials to the radio receiver, I have used 3 methods. During my childhood days, I used valve or germanium transistor radios with an external aerial connection, so i would just plug the aerial right in. Later on, when i moved to more sensitive radios, i discovered that connecting an external aerial to the telescopic aerial of the radio sounded nice mostly but also overloaded if the stations were powerful. A local HAM told me a little trick which involved taking a piece of hook-up wire, about a foot long and coiling it around the bottom segment of the telescopic antenna (which is not extended) ensuring that no physical connectivity happens. One end of this coil is to be connected to the external long-wire aerial. This is fantastic and gave me great results without upsetting the tuning calibration of my radios (caused by the constant overload with the direction connection). And then the same HAM gave me another idea - in those times, some radio cassette recorders would come with MW and SW radios, but with no antenna. For these what he said was, to simply take a metal plate, connect the external long-wire antenna to it and place it so as to rest across the back panel of the radio cassette. I recall using one of mom's old discarded stainless steel plates for the purpose with the aerial wire clipped on with a alligator clip. I also found out that connecting the aerial to a stainless steel vessel kept inverted and placing the radio over the steel vessel, also worked splendidly.
I also found out that if using power supplies (called battery eliminators in those times), one had to use proper filtering by adding filter caps and even better still, regulator circuitry. I used to do my experiments with filtering, by replacing the transformer output in my battery eliminator with electricity coming from a cycle dynamo (which was very noisy, electrically). I fondly recollect my brother peddling away on a bicycle on its stand while we fiddled around with combinations. For long distance reception, I always found batteries to be better as they offered 2 benefits, portability and of course, no direct contact with electrical interference sources. We could also carry our radio around in our locality, trying to ascertain the range of our small MW transmitter, which we made for fun and connected it to our long wire aerial. It was fun walking around in our locality, picking up the signal. Of course, as the batteries wore out, the radio would become less and less sensitive causing us to fiddle even more :)
Also an often forgotten or ignored aspect of radio reception is the time of the day and solar cycles. One cannot expect to receive MW long distance signals during the day and one has to switch between bands dropping to the lower frequency bands as the day turns to night, for SW listening. Read up some online info on Solar cycles (sun spots) and how they impact SW radio listening for more info.
Some good times and good memories :)
Additional info - shortwave bands and when best to listen:
Meter
Band
Frequency
(kHz)
ConditionComments
1202300 – 2495NightMainly used ‘locally’ in tropical regions
Also used by government in North America
903200 – 3400NightMainly used ‘locally’ in tropical regions
Used by various agencies of U.S. government
803500 – 4000NightAmateur (Ham radio) band
LSB (voice) and CW (Morse code) mode
753900 – 4000NightMainly used in Eastern Hemisphere
Mainly Europe, Africa
604750 – 5060NightMainly used ‘locally’ in tropical regions
Best reception during Fall and Winter
495900 – 6200NightPopular band for nighttime broadcasting
The best overall nighttime band for Int’l broadcasting
417100 – 7350Night / DayInt’l Broadcast, except North-South America
which is reserved for Amateur radio
407000 – 7300Night / DayAmateur (Ham radio) band
319400 – 9990Night / DayMost Popular Int’l broadcasting band
Best mid-afternoon to mid-morning
2511600 – 12100Mostly DayPopular Int’l band for daytime broadcasting
Good any time of day
2213570 – 13870Mostly DayInt’l broadcasting
Not heavily used
2014000 – 14350Mostly DayAmateur (Ham radio) band (Popular long-distance DX)
USB (voice) and CW (Morse code) mode
1915030 – 15800Mostly DayInt’l broadcasting
The best overall daytime band for Int’l broadcasting
1718068 – 18168DayAmateur (Ham radio) band
1617480 – 17900DayInt’l broadcasting
1521000 – 21450DayAmateur (Ham radio) band
1321450 – 21850DayInt’l broadcasting
Seldom used
1224890 – 24990DayAmateur (Ham radio) band
USB (voice) and CW (Morse code) mode, Best during sunspots
1125670 – 26100DayInt’l broadcasting
Seldom used
1028000 – 29700DayAmateur (Ham radio) band
Meter
Band
Frequency
(kHz)
ConditionComments
Not heavily used
Seldom used
Seldom used
Thanks Reuben, that was a treasure-trove of information. I dont know how but I am able to pull in crystal clear FM from AIR Mokokchung (Nagaland) sitting at Dibrugarh in Assam. Aerial distance would be 150 Kms+ and the radio is a old Sanyo with manual tuning with just its inbuilt antenna.
Please help.
If u want to sell,I will like to purchase.
Technical solution for your problem is connect a simple,single wire to antenna base and leave it on the floor....it will give good noise free performance.Try it.
