sonosphere
Hi everybody,
I have seen a moderate improvement in the overall blend of frequencies when I used a graphic equaliizer (though at a cost of moderate reduction in peaks that add sparkle to music).
To reduce the sound of boominess and harsh treble end reflections in my room, I am on lookout for a Parametric equalizer. I found this on net >>
Behringer DSP1124P Digital 24-Bit Feedback Suppressor/Parametric Equalizer < Electronics : Electronics - Shop in the US from India @ 20North
My Query:
1. The above referred unit only accepts XLR or 1/4" pin level signal as input (I believe the signal level accpeted in the input of this type of Professional gear is different from the consumer RCA line-out level). Is there any way to convert RCA line-out signal to XLR or 1/4" pin level signal, without undue signal-degradation?
2. Has anyone use this /similar unit for home use? How was the SQ after using this?
Thanks in advance,
Sonosphere
My Query:
Thanks in advance,
Sonosphere
