PCMCIA sound card with Digital out ?
arj
Moderator
Staff member
Does anyone know of any good PCMCIA soundcard which does a digital out ? all i could find was the indigo Echo but that only has an Analogue out.
Any info would be much appreciated !
PCMCIA soundcard
Hi...
Any particular reason why you are looking for PCMCIA based digital output ? If this is for your laptop, then you have USB/firewire based Audio devices which can give you what you are looking for.
One such product is M-AUDIO - Transit - Hi-Resolution Mobile Audio Interface which is the base product in USB connectivity mode. The firewire products from them are really more professional based and might be an over-kill for home use :)
Hope this helps..!!
i do have a trends UD10 with external battery pack..and it is not really good enough.
Also USB has some intrinsic problems for Hi fi :sad:
specifically looking for PCMCIA..unless you know of any ethernet to SPDIF :D
Okie Dokie..
I am not aware of any PCMCIA cards which provide COAX/DIGITAL outs.. if i come across one, i will let you know.
in case you find out before i do, then please let me know. I would like to know the product as well :D
