Philips HD Media player HMP3000
nitinmukesh
Pune
I have shortlisted the following media player as it is within my budget I am getting it for Rs 3600/-
Code:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=pl&ctn=HMP3000/12
Also it supports all of the major formats which I want like BD ISO/M2TS/MKV etc....
Code:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=HMP3000%2F12&dct=FAQ&faqview=1&new_tmpl=1&refdisplay=HAV_MEDIA%20BOX_003&refnr=0085360&scy=PL&slg=AEN
The only problem is it only supports 2ch audio and does not support DTS HD MA audio.
It lists that it has Digital audio output, if I connect receiver in Digital audio output which decodes all audio will it give 5.1 or 7.1 surround sound?
thanks for any help.
Can also consider 'Asus O Play Mini' for this budget.
Thank PRhythm. I already considered it.
Does not support Bluray/DVD ISO files.
Only support these Audio (Dolby Digital AC3, Dolby Digital Plus, DTS 2.0 +Digital out) which do not have DTS HD MA/5.1/7.1.
If you need all these features, then considers players from kaiboer, measy or himedia. They have some entry level players that support all the required features.
It has DTS 2.0 + Digital out and I think this answers it
Code:
http://archive.atomicmpc.com.au/forums.asp?s=2&c=9&t=10957
