pink noise for speaker burn in
rallynut
kerala
audio gurus,whats your take on using pink noise and freq sweeps for breakin in speakers??havin gone thru a lot of info regarding the same,i find that like most other theories this too has its own schools of thought.being a little bit of a believer myself in the phenomenon of break in:rolleyes:(at least initial few hours),was wondering if there are any downloadable files for the same.can i use the pink noise generator and test tones from burninwave??its used for earphone driver burn in(accordin to the author),but me thinks it should be usable for speakers as well.opinions??cheers
Buddy you can use Pinknoise and Whitenoise to burn-in a speaker or electronics :)! Be bit cautious when using whitenoise though !
The burninwave can also be used,you may have to fiddle with the volume though (as either they'll be low to suit the headphones or loud to burn the headphones real quick ) !
Alternatively you may buy a Burn-in disc and just use that instead of worring bout which type of noise to use etc..
There are few specialised discs but the major ones are "ISOTEK System conditioning Disc"
Another one is, "XLO Test & Burn-In CD"
Since you are in the US currently ( going by what you've posted in the other thread ) its very very easy to procure one :ohyeah: !
Both these CD's not have the necessary Burn-in track but also has the Demagnatise signal (for demagnatising the system from years of usage) and has a frequency sweep etc etc ,So I'd say this is the best option ! in case you are buying the CD please get me a copy of ISOTEK :p Shall gladly pay for it ;)!!
Regards.
soundsgreat,thanks for that prompt reply and kudos to all the diy stuff youve been doin!!awesome buddy.looks like ur goin to be part of the blore meet this mth.gonna miss that.would have love to meet u!!am workin abroad yes,but in the maldives(am a medico)!!dunno how to help u on the test cd issue:D.apologies.was plannin to get the pink noise generator downloaded from burninwave and use it.you may be right about the volume level,will confirm that.oh and did you know this concept of filtered noise generation seems to be helping a lot of people who have 'tinnitus' and have to live with the condition??amazing.cheers
Thanks a lot for liking my DIY efforts ! No probs we always meet some other time !
am workin abroad yes,but in the maldives(am a medico)!!dunno how to help u on the test cd issue.apologies.
Buddy no need to... its ok I never knew that you are in Maldives ! Usually when people say abroad and not mention the place its by default considered as US :p hence my assumption ! sorry for that !
Doc Am not one of your kind so this doesn't ring a bell :p !
Btw are you the guy who is interacting with Anand for a system ?? Coz I remember he mentioning about it ! just asking don't mind ;)!
Regards.
Best burn in option is to use a variety of music a bit lower than normal listening on continuous playback - DVDP or CDP with looping is best for this. I used to do this when going away for the weekend or evenings or during day for office and it easily hit the 100-150 hours within a week. You can change the genre of music once a day for ensure the various frequencies are touched upon.
Regards.
soundsgreat,..guilty as charged:ohyeah:.am sourcing my separates thru anand.great guy.managed to get the burninwave files.the volume levels dont seem to be an issue.will keep you posted once i get down to setting my hifi up.cheers
marsilians thanks for the adv.am plannin to use a mixture of pink noise and western classical for the same,along with some other genres.should be ok i guess.cheers
soundsgreat,..guilty as charged.am sourcing my separates thru anand.great guy.managed to get the burninwave files.the volume levels dont seem to be an issue.will keep you posted once i get down to setting my hifi up.cheers
Good to hear that its you ;)!! Yeah please do let Us know how it works out !
Keith are you by any the same guy from the Avmax ?? just remember the name from it ! don't mind me asking ;) !
Regards.
Regards.
Soundsgreat, I don't mind at all but I think you've got me mixed up with someone else. Me and AVMax? No connection at all.
My 2 cents worth:
Create your own .wav file with 10min of Pinknoise + 1min of Silence + 20-20000 Hz frequency sweep + 1min of Silence + heavyDrums + 1min of Silence
Individual files for all of these are available at: Burn-in wave files: white noise, pink noise, frequency sweep, channel mix
Worked great for me. Hope it will be good for you too.
keith,thanks for that input.was thinkin on similar lines.btw what setup do u have and how long did u continuously use the looping sequence for?entire mfr suggested time frame for break in or less?cheers
Initially I looped it for 12 hours before I did any serious listening. Then whenever I remembered to - I left it on loop for no specified time frame. I suggest that you do the same - or else you will be doing just burn-in's without enjoying your system. Happy listening!
got my mission m35i on the 10th and have been using noise files for their burn in.created my own sequence of the same from downloaded files(burninwave.com).thunderstorm+church hall+frequency sweep+heavy drums+pink noise+silence,and keep it on loop.i play this from my laptop-ipod cable-amp-speakers.usual routine since 25+hrs of playtime is noise file mix for 2hrs at system wake up followed by music(genre by genre) for the rest of the day.am sure it helps in the acceleration of the burn in process as the speakers have started to sound absolutely great,and i suppose can only get better!!!cheers
Am really glad to hear this Doc :) ! Yes Am sure it will only improve !!
Please do post some pics and such of the same for Us to enjoy and admire your setup !!
Regards.
Regards.
hey soundsgreat,yeah am more than just happy already :clapping:.anand is a great guy,he took the time and effort to come down to kerala and help setup everything.says a lot about him and all the talking inevitably got to DIY!!should be comin to blore soon,would love to meet up with you and audition ur setup,time permitting.hope ur projects are goin good.cheers bro
oh and am goin to post pics of the setup,soon hopefully!!
