jayantadak
Hi folks,
I just went through several posts and specifications of DV 610 and DV 220 DVD players from Pioneer. I am confused as to which should I opt for. The 220 appears to be an advanced one, but according to the reports there is hardly a player in that category to beat DV 610.
My main queries are 1) Do both players avi / Divx format files (i.e. movies downloaded from the net and later copied on the USB.
(2) Can I play avi/Divx files and other data by connecting the playr to an external hard disc.
(3) The DV 610 specifies that it plays DVD-Audio and SACD. Does it have any relevance since the DVD-A and SACD material is very rare and expensive too.
(4) Is there any specific reason as to the price difference between the two sets is Rs. 2000. The 610 sells for RS. 6500 whereas the 220 retails for RS. 4500.
Please let me know as I am zeroing on the DV 610. But if playability of DVD-A and SACD is the only other extra feature on DV 610, then I would rather stick to DV 220. No point in shelling out 2K extrra. If there is any other point to be considered kindly post.
JAYANT
JAYANT
