Playing atmos on Firetv
tapmal5
Delhi
I am using FireTV pendant which is 4K (connected to my Denon 2400) to play atmos content ie on Amazon Prime Video and also using VLC Player app from my network storage device but since most of the content UHD but my projector if 1080p so I am not getting atmos sound .Any suggestion ?
You are using FireTv or FireTV 4K?
FireTv doesn't support Atmos, only 5.1. FireTv 4K supports Atmos.
Even the fire tv 4k doesn’t support Atmos as it can’t bitstream. As per spec sheet only Atmos support is through amazon prime. While streaming from network it will not support Atmos, Dts HD and Dolby tru HD
As per my understanding, he is not getting atmos from both. (Amazon Prime and VLC player).
He should get atmos from amazon prime.
hi,
All i see here is a another frustrating user complaining about atmos audio in his firetv stick...
BTW can you get 5.1 output from your firetv stick??
Amazon Prime looks like does not support Atmos, I only get 5.1, I have Marantz SR8012 and Klipsch reference 9.2 set up. in Netflix i have the UHD plan there also I get only 5.1 but a very good quality image though
