Please recommend me a 1.5Ton AC
I am in the process of buying one too.
Since my usage is going to be more, I am thinking of going for Daikin.
You need to consider your room size and amount of heat it receives.
Look at the excel sheet uploaded here.
It has some simple guidance on how to shortlist one that suits your needs and some data on available models.
If your room receives too much heat consider heat reflecting paint.
The one you have specified will always blow the air at you directly. If thats OK with you, then it doesn't seem like a bad model. (I don't know if that feature can be switched off)
Since your usage doesn't seem to be too much, you don't have to go for a high end model. Make it inverter for sure.
Perhaps Sharp ?
