Polk RTiA3 as Centers
theraindew
Chennai, India
Hi all,
How would Polk RTiA3 used as center pair with Polk RTiA7s as front? Or have anyone tried using BS for centers? I am ready to buy an AVR, most probably Denon X2000. I have Tsi200 and PSW110 and will get the A7 very soon. I am actually looking at a 3.1 setup right now. If the BS is not a good option for center, then I will buy a CSiA4 now and use the Tsi200 as surrounds later.
Hi all,
You are better off with a dedicated center channel speaker as it is specifically designed to handle movie dialogues....
ok.. thanks. no RTiA3 then!
:D .. If you had already owned RTiA3 speaker, experimenting yourself with that as center speaker would be a good idea....Otherwise, getting the matching center is better.
BTW why do you think RTiA3 would be better than dedicated center channel speaker..
Was doing some reading.
Code:
http://forum.blu-ray.com/showthread.php?t=89614
I did follow the suggestion for SW (raising them) mentioned by the same FM and I have to say, the sound has become completly different. There is more punch (ok.. a little at least :rolleyes:) but the boominess is certainly gone.
