Projector for Church Suggest 20-30k
arunlouie
Bengaluru
I need to buy a decent projector in budget 20-30k (along with screen). Please suggest one.
- Consider this that church will be well lit as mainly useed only on weekend payer meet.
- Usage 4 hours per week
- A simple low profile screen in a tripod will do.
While epsons are good. You can try out viewsonic or benq projectors which come in business category. I own both of them and find the benq well build and its a tad bit more brighter than viewsonic. Look at the highest lumens on your purchase and forget about hd projector for this use.
Id it will be used for long hours, get one with an LED lighting source. The non LED bulbs are 3000 hours and they cost a lot. LED's last 20,000 hours. So better, yes watch for lumens. You want atleast 3000 and any less you need total darkness to see it. Under 2000, it will be washed out in even near total darkness.
Cool.
Srinath.
