quad 22L2 or B & W 684 speakers
I would recommend a Rotel RA-04 for the amp and any entry level NAD CDP. Or, for a better synergy, an all NAD system, NAD amp, NAD CDP.
I suggested Dali IKON because they are a great Jazz/Classic/Country/Soft Rock speakers. Over and above they are great all rounders. Excellent VFM.
Hi Nandkumar,
Both are good. But as unleash suggested the quad should suit u better.
For a cdp please try the Marantz sa 7001 or if finances permit the 7001KI. Better than anything in this price in my opinion.
For amplification i feel both these floorstanders require a bigger amp to shine. If its a rotel integrated try the Ra 1070 or else the pre powers. If opting for the nad then i guess the pre/power is the way to go. I had the 603 from b&W and the 684 is its replacement and in my experience they do sound much better with a big ,stable amp.
Try and audition ur proposed combo thoroughly to avoid any heartburn later.
Hi Ranjeet,
I disagree that the quads are classic rock speakers. In fact we demoed them with tons of classical and found the quads pretty accurate with complex orchestral peices.
I am referring to the 22L have not heard the new avatar but i guess it must be very similar.
Both these speakers would not be my speaker of choice but i guess they are both versatile enough to suit various needs.
REGARDS
Hi Ranjeet,
REGARDS
Hi mate,
No worries. We can have different opinions and still be friends :)
Actually Quad have a reputation as a Rock speaker. And the B&W that nandakumarhv mentioned uses a aluminium dome compression driver. IMHO, not good for classical.
nandakumarhv seems to be setting up a system from scratch and I didn't want him to go the wrong way.
I too am surprised to hear the Quad characterized as "rock speakers" since they are a bit removed from this. While pretty decent with rock, they excel at Classical and perhaps even jazz and make excellent partners for tube amps. When I first heard it 2 years ago it was partnered with a restored Quad tube amp (that could go for about 5-6 lakhs) and it is one of my more memorable listening experiences. Bit smooth for rock but definitely has the bass extension necessary to work well without a sub. I have not heard the new range either but do not think there will be stark differences as there are no major design changes. Hope they have retained that superb lacquer finish that made the older one look so classy!
I do not think it should be compared to B&W 684 at all. That is B&W's next-to-entry-level series and it gets better only from 700 series and up. But yes, price-wise in India it seems much costlier due to mark-ups.
If you are in Mumbai, I would suggest listening to Totem speakers at LaKozy at Chowpatty as well (do not know if they are in the showroom, I had heard them at Boom-a-rang at Juhu). They excel especially at percussion and are a pleasure to listen to Jazz on - perhaps it would do well with Classical or Fusion as well.
Okay, then difference of opinions.
Btw how much is QUAD 22L2 in India? If ProAc studio 125 is around the same price range, I would add ProAc to the audition list.
Ah, now I see you are in Bangalore. You are so fortunate to be in the midst of India's best speaker manufacturers. I start this post with the disclaimer that i have never been fortunate enough to hear any of the following but just look at the feedback (full of raves) they receive and that speaks volumes. Perhaps you should include Acoustic Portrait in your list (Acoustic Portrait). Also lets not forget Cadence (Welcome to CadenceAudio WebSite) - you have Cadence Aritas and their VA-1 amp in a similar price range. Some day I would like to make a trip to Bangalore just to hear these!
Quad 22L was around 75-80 back then. Must be lower now. Again as I said in another thread, even getting the old L stock will be a good idea as its prices will be lower if available.
I share that sentiment. I wish to have heard them all at one place vis-a-vis similarly priced kit from international brands.
List price given to me about three months ago was 60K for 22L and 72K for 22L2.
Could any one help me to finalise between quad 22L2 and B & W 684 speakers,
i listen to fusion and classical.
Please do add Dali Ikon 6 to your list.
I dont the Quads are ideal for rock music.
Consider the combo of Cyrus 8vs2 with the Dali Ikons. Excellent synergy.
If you can extend your budget, then the Proac Studio 140 is a very fine speaker.
Ofcourse you would need better amplification and a better source for the 140s.
SNV
...Consider the combo of Cyrus 8vs2 with the Dali Ikons. Excellent synergy.
Ofcourse you would need better amplification and a better source for the 140s....
Good speakers. Personally I'm not a huge fan of Cyrus; would suggest you the Marantz 7001 combo to begin with and if a stretch is possible then the awesome Primare combo. If you enjoy music in low volumes and still want all the good qualities, you must listen to the Dali Ikon 6.
Btw, guys....all of you are welcome to Bangalore. Its a wonderful city and yes, we audiophiles are a bit lucky here, what say?!
