naveenjn
Last time I asked for a suggestion here to replace my Logitech Z-5500 speakers, I was pointed to Edifier, a brand I hadn't heard till then. I was skeptical but still went ahead trusting you guys and I couldn't be any happier. The balanced output was much better than the bass blasting Z-5500.
Now I am looking to buy an inverter based split AC. I am from Trivandrum, Kerala. My room size is 240 sqft, top floor. I believe 1.5T inverter would cover this area. I currently have a 5 year old Whirpool 1.5T split (3 star I believe). The cooling was always slow and my electricity bill was always high. Now with Kerala government hiking electricity rates again and planning for another hike in Jan 2013, I am considering changing this AC.
I went through pretty much all threads here on inverter ACs. My normal AC usage is from 3 PM to 6:30 PM and 9 PM to 12:30 PM. I was thinking if I switched to inverter AC, I could run it continuously from 3 PM to 12:30 PM, while reducing the bill (or at least retain the current rates).
I visited some shops here in Trivandrum and not surprisingly most of them don't have inverter ACs at all. Here are the inverter ones I found.
Sharp 1.5T (AH-XP18MV) - Rs 43,500 + 1000 (installation)
LG 1.5T (BS-Q186C7M1) - Rs 58,990 + installation
Carrier 1.5T - Rs 43,750 + installation
Daikin 1.5T - Rs 46,400 + installation
Sharp and LG use R410A refrigerant while Daikin uses old R22. Not sure about Carrier. Shop guys said for Sharp inverter acs, only 1.5T is required up to 290 sqft (my room is 240, top floor). I also found on the net, the photo of a document from Sharp comparing inverter and 5 star ACs.
I am leaning towards Sharp due to lower price and installation as well. Has anyone bought Sharp inverter ACs? Is the price good? What about the other brands? And more importantly is 1.5T inverter enough for a 240 sqft top floor room?
