sushanthace
Hi Folks,
Where can we get SACD's or DVD-A in chennai ?
Sushanth
Sushanth
Can DVD-A be played on a normal DVD player/ passed to my receiver's DAC via coax?
regards
I guess you can play DVD audio using a normal DVDP
side question - how do you rip SACD/ DVD-A to play back from comp?
No you cannot play a DVD-Audio disc in a normal DVD player as the TOC (table of contents ) in DVD-A and DVD-V are different !
In DVD-A the Video_TS folder will be empty and the entire will be in the Audio_TS folder ! the exact opposite in DVD-V !!
Its Impossible to rip the SACD layer :indifferent14:!! no computer based drive is capable of reading that layer ! all you can do is rip the CD layer :sad:!
As with DVD-A either you use media players like Power DVD and such which is perfectly capable of reading the DVD-A or use some DVD demuxer's to convert the TS files into whatever required audio files !
Or play the disc through the comp and pass the digital via optical or co-ax to an AVR !
Hope this helps!
Regards.
Why don't you order from Amazon?
Here, even if you find you will not get enough choice.
Hi Metalbandit,
i checked Landmark but i couldnt find any SACDs there and the people there had no clue about what i was asking them...
Also can you please tell me the location for Odyssey?
...i checked Landmark but i couldnt find any SACDs there and the people there had no clue about what i was asking them...
As suggested by others, Amazon may be a better but expensive choice.
Hi sushanth,
Did u get to buy any sacds?
@ gurus here
It seems sacd multi channel cds can be played only thro a DSD capable AVR. is it true? I dont think my Onkyo 3100 AVR is DSD capable. Can someone tell me if i can play sacd's or DVD-A from say an Oppo DVDp thro my HTiB?
cheers,
sri
Hi sushanth,
cheers,
sri
