Samsung 43E490 3D plasma TV
dskchary
hyderabad
Hi All,
I am planning to buy the Samsung 43E490 43" 3D Plasma TV. Reliance Digital @ Hyderabad Quoted @ 42K with (blue ray player + 2 3D Glasses) free.
I have very little idea about the plasma/lcd/led tvs..
Please suggest the best TV.. my budget is around 40K to 50K. and looking for 40"+ Tv's.
Please share some reviews aboutthis tv and other best TV's....
Satish
It's a good deal @42K (including BluRay player). You can try to bargain for 40K. They do come down.
If you are going for 2yr extended warranty which is Rs 5.5K for 3D models, you can definitely ask for around 44 to 45K. Get quotes from various Reliance digital branches, and use that for bargain.
Plasma needs more power consumption and has brightness issues. I will recommend LED 3D TVs over plasmas. In your budget you can get a decent size LED 3D. If you are willing to buy plasma than consider Panasonic over Samsung otherwise you can consider Sony or LG 3D LED TVs.
Finally i brought Panasonic 42ET5d 42" 3D Smart Viera TV.:clapping::clapping::yahoo::yahoo::yahoo::yahoo::yahoo::yahoo:
