Samsung 48H5500 48 inches OR Panasonic Viera TH-50AS610D 50 inches - ADVICE NEEDED!
adityasingh5
INDIA
I decided to buy a new LED TV this festival season.
I narrowed down my choices to the Samsung 48H5500 48 inches OR Panasonic Viera TH-50AS610D 50 inches.
My main usage would be watching HD or Full HD Movies and TV Shows.
So, which of the above televisions would be better in regards to picture quality, smooth cinematic quality reproduction, contrast, colors, brightness etc ?
Also, please mention if you know of a better LED Panel within the range of Rs, 75,000.
Thanks!
Re: Samsung 48H5500 48 inches OR Panasonic Viera TH-50AS610D 50 inches - ADVICE NEEDE
I am looking for the same and if anyone tell me best price for Panasonic Viera TH-50AS610D?
panny panel is a good choice,i bought the non smart model of the same.however you can also have a look at sony kdl-48w600b.hope this helps.
