Davis George C
Sir,
I have a problem with a 32 inch Samsung LCD TV purchased 3 weeks back. While the TV is On, if any electrical switch is operated (tubelights or incandescent Lamps) the TV reception momentarily switches off and then comes On by itself. It should be noted that the signal from the Set Top Box is not interrupted because No-signal indication on the screen is not appearing. Could you suggest the reason for this happenning.
Davis
Davis
