Searching for LM8361 Clock IC: Pl Help
anuragn
Navi Mumbai
I am looking for clock driver IC LM8361 (by Sanyo). Its a very old obsolete IC and I am not able to find it anywhere. There are a few sellers on ebay but its costing more than $10. I dont feel its worth to spend more than 300-400 rupees.
I searched at Lamington road but did not find.
This is equivalent to mm5387, which is a more popular clock chip. Long ago,
Visha/Vega had a MM5387 based clock kit - not sure if they still have it.
There are other equivalent clock chips listed below, one of which you may find
locally.
http://preverdy.free.fr/ci/clock_mm5387/html/clock-mm5387-pcb.html
Alternatively, if you want to reuse the chassis with a new circuit, I can recommend
this one below, with a thermometer option too.
The 4 digit 7 segment display is just Rs 20/- in my local market,
and I can send you an eagle PCB design, but you can build it on a small breadboard as
it is a really simple circuit.
Digital Clock/Date/Thermometer with PIC16F628/PIC16F84/PIC16F690 and DS18S20/DS18B20
locally.
Thanks so much Quad. You've made my day.
Now I remember, MM5387 used to feature in lots of projects in EFY.
