Selecting lcr under 2 lakhs
deonddj
Kerala
Narrowed down my lcr selection to
Monitor audio bronze 500+ silver 250 center
Q acoustics 3050 + svs ultra center
Svs prime towers +prime center
Other options warfdale evo 5.3 with evo 5c center
Anyone with experience with the above speakers, especially the svs please help me out 😁
Klipsch Rp 6000fii and 500cii or 504cii
Focals? Second hand ✋?
Polk Legend series, Kef and XTZ also available in this budget. May have to stretch a little but speakers last long and spending a little extra for the perfect speakers is worth it
I will give a different direction for a better tonality that gives better music performance on top of the movies. Get the emotiva speakers if possible. I have found this performing very well with better clarity in dialogues and overall tonality, slightly cheaper and efficient as well
Which kef and xtz models do you suggest i look into?
Kef Q series will be excellent. They will be expensive but worth it. I have never considered an upgrade once I got them. Your taste might be different.
Their uni-q drivers are indeed special.
Kef>>Monitor audio >> Wharfedales in that order IMHO. Leave the rest to Dirac.
Ive decided to go with xtz spirit 11 and spirit 8 center. Only problem i see is that ill probably need a power amp .
