An AVR for music listening? Interesting :clapping:
Why not??? Tons of people are doing it. I do it. There are ways to improve the SQ as compared to the usual config. Use pure direct, by pass the AVR's dac and the preamp (this is the biggest culprit, I connect the asus essence output straight to the external decoder output, only volume control in AVR is effective). There are good quality AVRs too, just get the arcam AVR and see it beat the nads and marantz integrateds to a pulp. so you cant make a general statement that all avrs are bad and all integrateds are good.
The AVR vs integrated (or pre-power) might make a difference when your speakers are above a certain threshold. If you try this with a 10k polk, you probably wont find a different in sound quality, specially due to the amp. pre-amp might be a different ball game though.
There are stereo amps with sub outs but it still sends the full range signal to the speakers unlike the AVR's. The AVR's priced less then half the price of most budget stereo amps has the feature of selecting the upper cut-off frequency for subs and lower cut-off for satellites. But stereo amps costing 10 times its price don't have that feature why?
I dont know dude, why dont you tell why? I dont own an integrated, so dont know.
Dont forget that each and every speaker in the world (except a full range driver based speakers) has a high pass filter. Other wise your tweeter (and mid in a 3way) will not last a day:lol:
Sub Amp?
So now the amplified signal has to pass through an additional device which may spoil the purity of the sound.
The only additional device in this case will be a hpf. the signal does not pass thru an amp, it just connects to an amp. this option is only available on subs with speaker level input and output and then also its not necessary.
Also where will you find passive sub's to work with sub amps? A car stereo shop?
Dude, the sub amp exists in every active sub. if you ever get to see an active sub, you will find it in the back of the sub. so buy a sub that has this feature.
High pass filters/ active x'overs as part of stereo system?
I fail to understand why they are not available from full time hi-fi manufacturers like Marantz, CA, NAD, Creek, Roksan, Naim?
They exists inside almost every speaker thats a part of any stereo system in the world. what do you have against your hpf? do you have any personal experience with it or just what you heard from someone.
An active crossover cannot be a part of an amplifier as for this you need two amps not one. so how can you make it a part of it?
Integration means the sub has to work in phase with the main speakers. If out of phase is an issue like the sub not working as fast as the bookshelf's adding a second sub will not solve the issue and two subs will increase the cost. Also placing the bookshelf's on the sub may far be lower in height than the optimum listening height.
Most of the subs have a phase control switch or dial.
Of course it will increase the cost. who said hifi is cheap.
A 2 way bookshelf always sounds better than a 3 way speakers at the same price.
My point was regarding the placement confusion that people seem to crib about. Point is that if you keep the sub just below the BS, it kind of operates like a 3way in a sense that the point of origin of sound is almost similar to a 3 way.
Regarding the 2way better than 3way, I am on record in hfv on this already. Of course it will sound better in a given price point, as you can buy a higher series BS with better quality components. e.g. B&W CM series FS cost as much as 8 series BS.
BTW, I am talking from experience, I am running BS with AVR and a sub. Are you? have you tried it?
There is another option to use a good quality 7.1 channel sound card with an htpc.
