signal generator
doors666
bangalore
anyone made a diy signal generator.. looking for a good working schematic that some one can recommend... lots are there on the net, which one to pick... nothing with exotic/imported/expensive parts, should be locally available... something that can do upto some 20hz-500k/1mhz.. square (ttl), triangle, sinewaves... decent approximation of waveforms, adjustable pulse width is nice to have...
Why don't you use software based using your PC, they are freely available over internet....
dont want those... some of the waveforms are pretty bad with those.... also dont want my pc connected to circuits under test...
