Passive Loudspeaker Systems
Passive loudspeaker systems are the most common kind one finds in the home hi-fi market as they are economical to build. A single amplifier which amplifies the whole audio signal from 20Hz to 20kHz drives the loudspeaker system. Inside the loudspeaker system, a passive crossover network splits the amplified signal into three way - high, mid and low frequency to the separate tweeter, midrange and woofer speaker drivers. These speaker systems at most, have a tweeter & midrange passive level adjustment. Since the crossover is after the amplifier, it is difficult to design variable passive filters in the crossover for low frequency slope adjustment / calibration, to correct the low frequency response in various acoustical environments or spatial loads. The passive crossover also introduces power losses, signal & phase distortion, thus deteriorating the quality of the audio reproduced
Active Loudspeaker Systems
Active loudspeaker systems are not so common in the home hi-fi market as they are expensive to build. Although these days they are becoming more and more popular in home audio, they are usually built for professional applications as their performance can be far superior to passive loudspeaker systems. Inside the active loudspeaker system, an active crossover network splits the line level signal into three way - high, mid and low frequencies to the separate tweeter, midrange and woofer power amplifiers to their respective speaker drivers. Since the signal split is done at line level before power amplification, it is easy to design and provide advanced active filters for adjustment / calibration of the low frequency slopes for various acoustical environments and spatial loads. Also circuits for driver time alignment and phase alignment and various necessary compensations can be incorporated. The result of this is a flatter frequency response, maximum amplifier-driver efficiency and minimum distortion.
