Small Subwoofer for limited space.
Raghav
My brother needs a sub which needs to fit in a 9 inch space. The other dimensions can be 20", but the front width should be within 9.
2 subs that I have found are
1. B&W AS1
2. Q Acoustics 2070s
Can you help me with pricing and availability of the above 2 and also recommend other options. Did not want to go with Yamaha, Onkyo etc...
Raghav
You shoudl look for a powered subwoofer with a 6 inch driver. Whats yoru budget - You also have the option of certain micro subwoofers
Yes. I am looking for a powered sub of 6 - 6.5 inch driver. I do not think one with a 8 inch driver could fit in the space.
The B&W AS1 is 85W and has a 6.5 inch driver.
View the AS1 at Bowers & Wilkins - The World's leading Home Theatre Brand
The Q Acoustics 2070s has two 6.5 inch drivers.
Q ACOUSTICS 2070 SUBWOOFER at hifix.co.uk
Budget is approx. 15-25k. Lower the better:ohyeah:
What micro sub you suggest?
Raghav
Velodyne Micro Vee is a great performer for its size and comparatives. One thing I want to caveat with is that you wont get room shaking performance at this. For subwoofers, size does matter!
Did check this but none of the dimensions is less than 9 inches.
Raghav
