arunvenkatesan
Friends
Need some help for converting SME 3009 tone arm ( II improved with fixed head shell) din 4pin connector to RCA. as my original 4 pin horizontal connector is kind of loose and comes out when the cable is moved. May be i can fix it but would like to know if converting to RCA sockets will make some improvement. have seen some conversion kits on the net but not sure how to go about it.has anyone got some experience in this?
also would like to know a decent Preamp ( with mm/mc) which can go with Nad 2100 /sansui QRX 7001.(later on with some better power amp also) have used the phono stage of QRX . will there be an improvement if I use a separate preamp/phono stage with sansui receiver.
Haven't listen any other real TT setup other than my incomplete gear. eager to listen some of our chennai FM's setup if it is not a trouble ( will be home 2nd week)
thanks
Arun
thanks
Arun
