well have u heard of WD HD player it know to play MKV files and it costs about 7k*.
well i have used a 26inch lcd as a monitor and it was not good for my eyes,i have used a friends 28inch lcd monitor from viewsonic which has a resolution of 1920x1200 and it was a whole lot better,dont forget there are many people who use 30inch lcd monitors at 2 feet.
well just because sony advertizes it as SPVA doesnt mean they use a SPVA a article written at display seach or digitimes not sure which one confirmed that sony has order a large number of lcds from AU optronics,the T series is a replacement for U series.the author of that article mentioned that the low end sony lcds uses AMVA panels.while SPVA are reserved for high end.
dell lcd monitors its 2007wfp model became popular because it had a IPS panel but slowly they started to use SPVA panel,and samsung lcds monitor can have any type of VA based panel ,mostly the worst i.e CMO based SMVA are dumped in asian countries ,to a lesser extent in europe most of samsung 32inch tv have cmo panel in india except for the high end series 6.
while samsung is know to use CMO panels in series 5 and below ,samsung and sony have a 50:50 jv in developing the S lcd ,sonys market share is small compared to samsung,so to keep up with the demand samsung usualy dumps tvs with CMO panel SMVA tech in asian countries except japan,korea.
while sony uses AMVA panel in low end lcds.the samsung and sony SPVA panel SUPPLY is less then demand,so samsung to larger extent is forced to use CMO panels while sony whose market share is less, uses AMVA panels to a lesser extent.
also sony W series and samsung series 6 for sure use the same SPVA panel yet sony has the contrast advantage reason being sony uses a proprietary backlight to boost the contrast.so if the T series is advertized has 1800:1 just because the S series has the same advertized contrast doesnt mean they use the same panel.
in 2007 the low end sony 32inch U series used a AMVA panel and was advertized has 1500:1 contrast ,at the same time the sony 32inch S310A,V300A had a contrast of 1600:1 even though samsung S plant advertized it has having 1200:1, how was sony V,S series able to achive the contrast advantage compared to samsung and sony U series ,the answer by using the proprietary backlight.
and finaly u can for sure see the difference b/w sony 32inch T and sony 32inch S in showrooms urself.
