Does this player supports 220V or voltage converter is required?
How much you paid ?
Did you get the player ? If you using firestick and BD player .. did you found any difference in sound performance?
I have done many comparisons side by side with my sony blu ray player and firestick. There was a huge difference in performance and mine is just a basic entry level blu ray player.Did you get the player ? If you using firestick and BD player .. did you found any difference in sound performance?
yes, given that when you consider the other expenses in bringing it here, why not cough up a bit more for a X1000/X1100ESDo you mean X800M2 vs X1100ES...?
Yeah but since YouTube audio quality is bad not much difference. Only the volume level will be better in the Blu-ray player. You don’t have to go for a premium Blu-ray player. The 10k ones will do the job and Sony 700 4K player is good. Available for 23kJust consider the Youtube with same song/scene is there difference ? is it worth to get premium BDR
Why not the 1100es?
sonyreconsidered.com
Congrats, Superb.Bought a SONY X-800M2 4K player from Best Buy, Chicago... bundled with 2 free discs... hopefully arriving next week.
That's some logical thinking and practical choice hydrovac!
So, earlier DUNE 4K media player, and now 4K Blu ray. Looks like you are heading towards 4K UHD set up... what about the display?
Have you hooked up the player yet...? if so, we are eager to hear about the impressions.
Thanks Haribabu,
Yes, this is an amazing universal player... have you auditioned this model?
I tested the SONY X-800M2 in my existing set up by replacing the Panasonic DMP-BDT360GA. Played the 4K disk on1080p display.
Jumanji
4K from hard drive via DUNE 4K duo
Beauty and the Beast
I have the same series model (x700) which has buit-in the same audio/video codecs.
only thing is that you have to use high end 4K HDMI cables, for best audio quality use separate HDMI for Audio to connect AVR.
Happy listening
Congrats, Superb.
It's enhanced model of x800 which supports all formats like Dobly Visual, Dolby Atmos etc.
Above all great sound quality, great streaming ability and visual enhanced.
