SoundFoundations - Isolation and vibration control Family
magma
Some products relaunched in new avatars
Isopod - grey semi hemispherical silicon based vibration absorber
Isobrick
Cork and seratted neoprene sandwich absorber
Sure spikes - aluminium and stainless steel composite spikes
Cerapod / ball
New Avatar in champagne and black
Ball based. Isolater for speaker and smaller equipment
Roller ball/ block
Simple but serious result oriented tungsten ball and t9 al cup based isolater
Cerabase
Cnc machined multiple ceramic ball based isolater with level adjust
For power amps, TTs, heavy equipment ,
I got two sets of cerapods recently for my streamer & Pre-amp, and was very impressed with the the improved sq. Impressed enough that I just ordered another set, to use under the pre. in my 2nd setup. I am already using a set of cerabases under my amp.
Great job, Ali.
Sid
Congrats Magma, can you mark the items by numbering them so its easy to understand which one is being described or share separate pictures.
Hifimart has got all of them
Named , catalogued and with pictures
I use the Roller Blocks under all my components. Highly recommend.
Bought some tungsten carbide balls as an upgrade to the regular balls. I know Magma also offers these as an upgrade.
Tried the roller blocks but the equipment is not stable. Is it supposed to be this way?.
