Speaker suggestion for Onkyo 606
gap g j
Trichy
I intend to buy SR606, I have very tight budget and I'm not able to buy speakers now.
I have 3 way speaker which came with the Sony hifi system that we bought in Singapore, Which sounds very good, I intend to use this speaker for front and it has 8 ohms impedence. And I have a powered sub which came free along with the 29" T.V. The Sub is down firing with adjustable frequency from 50Hz to 150Hz.
And I need center and 4 surround only. I asked the price of 5.0 speaker package but the dealer does not recommend this and he insist to buy a full HTiB saying the mismatching speakers will either blow the speaker or the receiver itself.
Members please help me to decide whether I can use Sony Speaker (8ohms) for front and surround speakers which may be 6 ohms and later upgrade my front to Floor standing speakers.
Thanking you in advance
Gap G J
No i'm asking about whether speakers of different ohms can be connected to the AVR, will it damage the AVR.
There is no harm is connecting speakers of different impedance in a 5.1 set up. In such a situation, the AVR has to be set up carefully, as it will have different loads on the various channels. I am not sure about the 606, but in some AVRs you can specify the impedance for each channel.
Visit a few Sony dealers and see if you can get speakers of the same impedance. If not, you may have no option to do what you are asking for.
I am not sure how it will sound though.
kk.you can connect spk with impedence mentioned in manual.
ie.manual says you can select from 6 to 16 ohms.
So no Harm.
So no Harm.
Thanks Spirovious,
I to downloaded the manual and saw in it, but the sales person said you cannot connect it. why did he discouraged me from going for a good AV?
Gap G J
Thanks Spirovious,
Gap G J
Generally sales person dont have enough knowledge.I experienced many times when I asked simple Q from impedence to THD etc.
So if manual says you can connect 6 to 16(in High end 4 to 16 ohm),you shldnt worry.
In my case my AVR manual says I can connect 8 to 16ohm(no 6ohm),I asked to Onkyo service centre(personally I went),they said even it is said so ,still 6ohm spk can be connected as Onk makes avr with minimum imp of 6ohms.
So finally 8 ohm Sony spk cannot make any problem & others with 6 ohms are recommended.
