Speaker wire recommendation needed
Wharfedale EVO4.4 Speaker
Michelangalo
Pune
Hi, I am keeping a budget of 1500-2500 for 25-30m OFC speaker wire. Based on the budget I have shortlisted few
1. DAC 16awg OFC speaker wire 30m cost- 3100
2. Amazon Basic 14 Awg 30m cost -2600
3. C&E 16 AWG wire 30m cost 2700
Please suggest something from the above. Also open for any better suggestions you might have. Please dont suggest anything that's above the mentioned budget. I don't want to spend a bomb on speaker wires.
Is it okay to use different brands speaker wires.
For reference I am using Stackfine 16AWG OFC speaker wire for the front which I got free with the speakers. Is it okay if I use a different brand wire for the center and rear speakers?
Prodigy
I was using Kasper 13AWG and now moved to Amazon Basics 12AWG as the kasper I had was in different lengths.
I felt the Amazon 12AWG is good only.
drkrack
Hyderabad
I'm using C&E 12awg for HT speakers including Atmos ; go for 12awg minimum, it's onetime investment
superczar
if the wires are concealed (or ugly looking wires are not a concern) , nothing will beat polycab/finolex 2.5sq mm
It’s copper (and not copper coated aluminum), has extremely low resistance per meter , 50+ strands (keeping inductance and capacitance low) and is the equivalent of 14 gauge at the princely price of 20 Rs a meter (make it 40 actually as it’s sold as a single wire)
If the run distance is more than 10m , esp for the LCR, you can opt for the 4sq mm variant
raghupb
Bengaluru
2.5 sq mm is approx 13AWG.
I have been using Finolex in 3 rigs.
No complaint
Raghu
Prodigy
No complaint
Raghu
Can we use the electrical wires as speaker wires?? Are those better than the ones that are sold as Speaker wires? If that’s the case, I have couple of meters of Polycab wires lying around and I would be glad to try them out.
raghupb
Bengaluru
Electrical wire is copper. Finolex/polycab are ofc. Use them and hear the speakers out.
Raghu
RRR
Between Polycab and Finolex which one is recommended for making an extension board of 2m.
superczar
You will find other esoteric philosophies on this but scientifically speaking, speaker wires are also electrical wires the same way as finolex / polycab wires are.
Speaker wires are however paired for convenience while the latter aren't.
And yes, your spare polycab wires will work.
If you do want an over-engineered solution (and i mean it in a good way), get a fresh set of thick 2.5mm (or 4mm) wires unless you know your spare wires are the same spec or better
Prodigy
Got it. I will give it a try and see. Since now it’s work from home for me I’ll do it and see.
I do have one thing that’s stuck in my mind for sometime.
I read in several other forums that the speaker wires have to be of same lengths. For e.g the front L & R speakers need to have equally long and not 1 short than the other. If my AVR is closer to the Left Ch, then is it that I cannot have 1 wire of 3 feet abs the other 10 feet.
is that theory right and also I have also read discussions on having at least 2.5mts as minimum cable lengths.
plesse advise.
superczar
plesse advise.
It’s a rule of thumb in that you want the wires to roughly be the same length.
This is done to ensure that resistive losses remain approx equal so that one speaker doesn’t sound louder than the other.
It’s ok to have say 5 meters for L and 6 for R.
What you don’t want is say 1 meter for L and 25 m for R.
Having said that , any differences on account of unequal cable lengths will be very subtle and can always be corrected through the gain control on your AVR.
So if someone has already wired with unequal lengths and put the cables in a conduit, it would not be worthwhile to re-wire but for a fresh setup, you might as well keep ém equal
And no for the latter, you can keep your cable lengths as short as you want
spirovious
Polycab 1.5 sqmm actually sounds dyanamic than 2.5 or higher guage when compared side by side.
I can suggest ICE cables which l heard with Pioneer LX303 and Dali speakers.For the price, they sounded good.
Yes, wires are wires.Only final sound quality which can matter.Most of Cinema Halls use electric cables for their speakers.
raghupb
Bengaluru
plesse advise.
This is to accommodate any future placement changes.
2.5m (6-8 ft) is a reasonable length to allow sufficient slack on the wire.
If asymmetric lengths, keep it within 1-2 feet difference for your sanity.
With electrical wire, you have the advantage of doubling up to increase gauge if needed.
This is assuming you have enough wire
Raghu
Prodigy
This is something new i learnt. I always believed the multiplexes used expensive speaker grade wires to run such setups.
raghupb
Bengaluru
In the professional world, things work differently.
Cost to benefit ratio is very important.
And ruggedness, replacability is a factor too.
Raghu
avtar2008
Gurgaon
can we mix 2 types or wiring? I am planning to use amazon basic 12awg for ear level speaker and polycab 2mm double core electric wire for all overhead wiring.
