speakers for Denon1200
NivAk613
Chennai
hi
everyone...!
This is Saravanan from Chennai. After a small survey and research about AVR's I found and I settle with Denon AVR-X1200 7.2 Channel Full 4K Ultra HD A/V Receiver with Bluetooth and Wi-Fi and pair with Q Acoustics 2000i series 5.1 speakers but it seems the price tag is above my budget. Hence I thought of going for some other low budget speaker without compromising the Quality. Then I found Boston XS 5.1 home theater speakers where i can get it for around 22k from Snapdeal and ebay. But my concern is whether Boston surround sound speakers withstand the output that comes from Denon 1200. I couldn't find any exact specifications that shows the max power input for these speakers. Hence I request if any one can provide me a proper solution or if my choice is wrong then let me know the best cost effective speakers that suits for Denon 1200.
Hope someone will provide me the solution for my query
hi
everyone...!
Yes..You can pair the Boston XS 5.1 with Denon 1200 safely... Look for Efficieny/sensitivty of the speaker http://www.bostonacoustics.com/DocumentMaster/US/lit_SoundWare_XS51.pdf
The satellites are 85db efficient.. So Denon is good enough..
How would Q Acoustics 3020 sound with Denon x1200W? I am planning such a system with 5.1 and eventually 7.1 around Q Acoustics 3020 though I plan to use Wharfedale Subwoofer as there are reviews which say that Q Acoustics 3070 SW are not very musical and there were other not-so-good reviews about the SW. Please share your thoughts.
